[Mapbender-users] There are no guis available for this user: root
María Mares
mmaress82 at gmail.com
Tue May 10 08:24:06 EDT 2011
Hello!!
I am new to this list and also new with Mapbender.
I installed Mapbenderwith the package: MS4W, I have done all the
installation according to the documentation page (1).
When I finish, go to the Mapbender Setup-Checker (2) all the parameters
I get OK.
But trying log with the user and password: root/roottells me that "There
Are guis not available for this user. "
I have done the installation several times but not in what can go wrong,
the database created by the install-2.5.2.bat does appear full of tables
and other ...
Some ideas please?!
Thanksand sorry by my english of google... i'm spanish.
(1):
http://www.mapbender.org/Manual_Installation#PHP_Configuration_PHP_configuration
(2):
PHP Configurationcheck
php Version X Version: 5.3.6
interface X Modul-PHP
path to php.ini X C:\ms4w\Apache\cgi-bin\php.ini
extension_dir X /ms4w/Apache/php/ext/(check the path, is it correct?)
session.save_path X /ms4w/tmp (check out the authorisation of the dir)
memory Limit X 128M(running in memory-trouble with printing? Perhaps
raise your memory limit)
error-reporting
(Your error_reporting configuration is not implementet into this test
yet. You shoul know what you are doing or set it to E_ALL & ~E_NOTICE)
session.save_handler X session.save_handler = files
file_Uploads X On
allow_url_fopen X On
short_open_tag X Off
JSON support X Native PHP
PHP Extensioncheck
MySQL check X MySQL installed
PostgreSQL check X PostgreSQL installed
GD2 check X GD installed
mbstring check X mbstring installed
gettext check X gettext installed
Database check
Administration Database X PostgreSQL
Connect to Database X connected
MD5 support X md5 supported
PostGIS check
PostGIS support X PostGIS function available
Version X POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21
August 2008" LIBXML="2.7.6" USE_STATS
Mapbender Configuration Check
Administration Database X pgsql
DB-Server X localhost(is this your DB-Server)
Mapbender-DB X mapbenderdb2(is this your Mapbender-DB)
DB-Owner X mapbender(is this your DB-Owner)
PREPAREDSTATEMENTS X set to 'true' and php 5.3.6 should work
CHARSET X UTF-8
TMPDIR X ../tmp
OWSPROXY X http:///owsproxy(Is this the right URL to your OWSPROXY?)
AUTO_UPDATE X set to 0: (see the result of the test and update WMS
manually)
ERROR LOGGING X Successful.
LOG_LEVEL X set to 'error': -Mapbender-errors will be logged
PORTAL X true(Users can create theirs own accounts)
MAXLOGIN X 3
Login-Path http://localhost/mapbender/frames/login.php
(If this link doesn't work, check your url to 'Login' in your mapbender.conf
Perhaps an alias in your httpd.conf will solve the problem, too)
Legend:
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110510/7f9d5108/attachment.html
More information about the Mapbender_users
