[Mapbender-users] Load WMS Error
Ramesh De Silva
desilvarami at gmail.com
Thu Jul 26 00:33:19 PDT 2012
Dear Thomas,
Thanks for the directions. By referring to the log file; I found that
"mod_loadwms.php" is referring to a non existing column (uuid) in the
relation "wms". So I just added a new column in the relation "wms" in
postgres level. Then; when I tried to load the WMS; again I got a similar
issue for another relation (this time relation "layer"). I did the same
workaround. After that I was able to load the WMS without any errors.
I wonder whether it requires to address this issue in
"pgsql_schema_2.5.sql".
Thanks again.
Cheers
Ramesh
On Thu, Jul 26, 2012 at 1:59 PM, Thomas Baschetti
<info at thomas-baschetti.de>wrote:
> Hi,
> do you see any errors in your logfiles (php and postgresql)? Perhaps you
> have to activate logging to see something there.
> Which MS4W-Version are you using?
> Thomas
> Am 26.07.2012 05:29, schrieb Ramesh De Silva:
> Hi,
> When I try to Load a new WMS ( which is running in the same machine)
> using the "Load WMS" option provided in admin interface; I come across the
> following error message. I use Mapbender version 2.7.3.
> *file:
> http://***.***.***.192/cgi-bin/mapserv.exe?map=/ms4w/apps/srilanka/sl.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0sqlerror: ERROR: unnamed prepared statement does not exist ROLLBACK
> performed....*
> But if I try to load the same WMS temporary using the "Adding WMS"
> option in GUI Template Application; it works fine. Assuming it is a
> database error; I tried with different versions of PostgreSQL ( V 8.2 and
> 9.1.4); but the result was the same.
> Also if I use an older Mapbender version ( V 2.4) the WMS
> loads permanently without any error.
> Please provide me any possible solution for this issue.
> Thank you.
> Cheers
> Ramesh
> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapbender_users
> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
> Hakenstraße 8D
> 49074 Osnabrück
> Tel: 0541 25 91 90 | mobil 01577 189 25 91
> E-Mail: info at thomas-baschetti.dewww.thomas-baschetti.de
> Ust-IdNr.: DE264355072
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20120726/35f90306/attachment.html>
More information about the Mapbender_users
