[Mapbender-users] Problems with FeatureInfo and WMSLoader, both not loading requested data
Astrid Emde astrid.emde at wheregroup.com
Thu Jan 23 02:57:16 PST 2014
Hello Richard,
this is a bug in Mapbender3 version 3.0.2. We added signature for Services
and noticed after the release that we did miss some parts. But they are
fixed in the nightly packages.
Please update your Mapbender3 with a package from
http://mapbender3.org/builds/nightly/
Best regards
Astrid
On Thu, January 23, 2014 10:53 am, richard_struggle wrote:
> EN:
> Hello to everyone,
> I am using mapbender v3.0.2 (package version) with apache 2.4. So far I
> was able to create applications with different elements. The most things
> are working well, but I got some problems with the featureInfo and the wms
>  loader. For WMS Loader I can activate the dialog and enter a get
> capabilities url. But after klicking 'load' I get the pop-up message:
> "WMSLoader: a wms
> capabilities can't be loaded!". I tried to analyse it with firebug and
> found a '500 internal Server error' (Status) at localhost (Domain). (URL
> is valid, tested at other webportal, service was loaded) Similiar with the
> featureinfo: after clicking on a feature I get the feature
> info dialog with tabs of the layers that contain queryable featureinfo,
> but no featureinfo itself, only the name of the layers. Same thing
> analysed with firebug: '500 internal Server error' (Status) at localhost
> (Domain). (Layer
> contains queryable features, format is set to text/html) I guess this two
> problems may have the same origin, but I really don't know what to do.
> Hope someone can help me.
> Thanks
> Richard
> DE:
> Hallo alle zusammen,
> Ich nutze gegenwärtig Mapbender v3.0.2 (die Packet-Version) mit Apache
> 2.4
> als Webserver. Ich habe bis jetz auch schon zwei Anwendungen erzeugen
> können, die größtenteils fehlerfrei laufen. Allerdings habe ich
> Probleme mit
> den Elementen GetFeautureInfo und WMSLoader. Beim WMS Loader kann ich zwar
> den Dialog aufrufen und eine getCapabilitiesURL eingeben, aber wenn ich
> den Dienst laden will, erscheint eine PopUp-Meldung: "WMSLoader: a wms
> capabilities can't be loaded!". Ich hab versucht mit firebug zu
> analysieren, wo der Fehler liegen könnte und bin unter Netzwerk bei
> dieser Anfrage auf den Statusfehler '500 internal server error' bei der
> Domain localhost gestoßen. (Die GetCapabilities-URL
> funktioniert, getestet auf einer anderen Website mit anderem Kartenclient)
>  Für den FeatureInfoDialog ist es ähnlich. Ich kann zwar die Funktion
> aufrufen und ein Kartenelement anklicken, dann erscheint der
> FeatureInfoDialog. Der enthält allerdings nur leere Tabs von den Layern
> welche abfragbare Features haben, zu dem angeklickten Element selbst gibt
> es jedoch keine Infos. Auch mit firebug überprüft, selbes Ergebnis:
> Statusfehler '500 internal server error' bei der Domain localhost. (Die
> Layer haben abfragbare Elemente, das Format ist auf text/html eingestellt)
>  Ich könnte mir vorstellen, dass beide Probleme dieselbe Ursache haben,
> aber ich weis wirklich nicht woran es liegen könnte. Ich hoffe jemand
> kann mir weiterhelfen.
> Grüße
> Richard
> http://osgeo-org.1560.x6.nabble.com/Problems-with-FeatureInfo-and-WMSLoad
> er-both-not-loading-requested-data-tp5099607.html Sent from the
> mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
