[Mapbender-users] MB 2.7.x: Can't save wms application settings
lukas.bollack lukas.bollack at naturnetz.ch
Mon Feb 29 06:46:18 PST 2016
Ok - a bit confusing, in the wiki I think it says to make these entries in
httpd.conf
Do I also need to make changes in mapbender.conf here?
# Definitions for HTTP Authentication
define('REALM', 'mapbender_registry');
define('NONCEKEY', 'mapbender');
$nonceLife = 300;
define('HTTP_AUTH_PROXY',"https://".$_SERVER['HTTP_HOST']."/http_auth");
//Problem - behind a rewrite rule - define it hardcoded?
Also I'm unsure if it's right if my entry for owsproxy is this:
define("OWSPROXY", "http://188.226.178.194/owsproxy");
This is the URL towards which the Alias /owsproxy points (or will be
pointing)
View this message in context: http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5253398.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
