[Mapbender-users] MB 2.7.x: Can't save wms application settings
Armin Retterath armin.retterath at lvermgeo.rlp.de
Mon Feb 29 07:02:52 PST 2016
yes - you have to make this changes too. you may also define following
for your owsproxy (maybe the server will became a name somewhen ;-) ) -
and if you have no certificate please exchange https with http in the
HTTP_AUTH_PROXY definition
define("OWSPROXY", "http://".$_SERVER['HTTP_HOST']
."/owsproxy");
On 29.02.2016 15:46, lukas.bollack wrote:
> Ok - a bit confusing, in the wiki I think it says to make these entries in
> httpd.conf
> Do I also need to make changes in mapbender.conf here?
> # Definitions for HTTP Authentication
> define('REALM', 'mapbender_registry');
> define('NONCEKEY', 'mapbender');
> $nonceLife = 300;
> define('HTTP_AUTH_PROXY',"https://".$_SERVER['HTTP_HOST']."/http_auth");
> //Problem - behind a rewrite rule - define it hardcoded?
> Also I'm unsure if it's right if my entry for owsproxy is this:
> define("OWSPROXY", "http://188.226.178.194/owsproxy");
> This is the URL towards which the Alias /owsproxy points (or will be
> pointing)
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MB-2-7-x-Can-t-save-wms-application-settings-tp5244512p5253398.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
