[Mapbender-users] Setting snapping distance of search results
Max Gruhlke Gruhlke.Max at arc-greenlab.de
Sun Feb 19 23:55:38 PST 2017
Hi there,
I experienced the following behavior using the identify tool in Mapbender 3.0.5.3.
1.       I found an object, using a search router and zoomed to the desired feature.
2.       I activated the identify tool and clicked right at the highlighted position. The feature Info returned no result.
[cid:image001.png at 01D28B57.18A3CF90]
3.       A click right at the symbol itself returns a result.
[cid:image002.png at 01D28B57.18A3CF90]
Creating the style-definition of those pins, I had to set a displacement in order to place the tip of the pin right on the coordinates of the feature.
Is there a way to increase the snapping distance of the identify tool?
Thanks for your help.
Sincerely,
Max Gruhlke
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170220/be9122b4/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170220/be9122b4/attachment-0002.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170220/be9122b4/attachment-0003.png>
More information about the Mapbender_users mailing list
