[Mapbender-users] Setting snapping distance of search results
Astrid Emde
astrid.emde at wheregroup.com
Mon Feb 20 00:25:37 PST 2017
Hello Max,
you have to increase the tolerance for the FeatureInfo of your WMS.
For MapServer you can do it with the TOLERANCE Parameter. Derfault is 3
pixel.
http://mapserver.org/mapfile/layer.html
TOLERANCE 10
TOLERANCEUNITS pixels (pixels is default)
For other WMS you have to check their documentation.
Astrid
Am 2017-02-20 08:55, schrieb Max Gruhlke:
> Hi there,
> I experienced the following behavior using the identify tool in
> Mapbender 3.0.5.3.
> 1. I found an object, using a search router and zoomed to the
> desired feature.
> 2. I activated the identify tool and clicked right at the
> highlighted position. The feature Info returned no result.
> 3. A click right at the symbol itself returns a result.
> Creating the style-definition of those pins, I had to set a
> displacement in order to place the tip of the pin right on the
> coordinates of the feature.
> Is there a way to increase the snapping distance of the identify tool?
> Thanks for your help.
> Sincerely,
> Max Gruhlke
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Winterschule 2017
20.-24.03.2017 in Bonn
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
