[Mapbender-users] Mapbender3, GetFeatureInfo-Window, Problem with Internet-Exporer 11
Uwe Seher
uwe.seher at gmail.com
Mon Feb 20 02:45:50 PST 2017
Hello!
the info format is set to text/html and we had no problems with IE until
now. Firefox and Chrome work also as it should be.
These are the formats as they are provided by GetCapabilities in the
GetFeatureInfo-section:
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<Format>text/xml</Format>
<Format>application/vnd.ogc.gml/3.1.1</Format>
<Format>text/xml; subtype=gml/3.1.1</Format>
<Format>text/html</Format>
<Format>application/json</Format>
<DCPType>
</DCPType>
</GetFeatureInfo>
It is a strange problem, and it took me at least some time to reproduce it.
Today i thought, the issue is the different version, because i could
reproduce the error with it. But later we found a new version browser that
works correct. So i think this may be a problem in the browser settings or
security level. Or is it possible, that IE ignores the into format settings
in some cases? I have no idea.
Best regards
Uwe
2017-02-20 10:46 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hello,
> Am 2017-02-20 10:31, schrieb Uwe Seher:
>> Hello group!
>> One of our users has a problem with the info-window on IE 11. It shows
>> only the string [object XMLDocument]. the service behind is a
>> geoserver, it works perfect on firefox and chrome.
> After loading a service to an application you have to make sure, that
> infoformat is set to text/html. I your case it is set to
> application/vnd.ogc.gml as the GeoServer getCapabilities-XML does not
> provide text/html as first infoformat in the xml.
> http://doc.mapbender3.org/en/book/quickstart.html#configure-your-wms
> The
>> Mapbender-Version is 3.0.5.3, the logfile does not show any relating
>> entry. I checked the versions of ie and the problem seems to be
>> limited on the version:
>> Version: 11.0.9600.18537
>> Updateversion: 11.0.38 (KB3203621)
>> The older version 11.0.9600.18097/11.0.25 (KB3100773) seem to work
>> without problems.The IE is in default configuration. Strangely, on
>> some installations with the newer version it works too.
>> I had this error-mesage some other times, when there has been an error
>> in the templates for the GetFeatureInfo-Request. I think this is a
>> problem with the local browser with the processing of the answer to
>> the request, but i have no idea where to look, so if someone has an
>> idea whats the issue here, it would be great to share it.
>> Thank you
>> Uwe Seher
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Best regards
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170220/07bf266a/attachment.html>
More information about the Mapbender_users
