[Mapbender-users] Mapbender3, GetFeatureInfo-Window, Problem with Internet-Exporer 11
Uwe Seher
uwe.seher at gmail.com
Tue Feb 21 00:58:29 PST 2017
Just for Info: Some other applications seem to have problems with this
version of IE.
Have a nice day!
Uwe
2017-02-20 11:45 GMT+01:00 Uwe Seher <uwe.seher at gmail.com>:
> Hello!
> the info format is set to text/html and we had no problems with IE until
> now. Firefox and Chrome work also as it should be.
> These are the formats as they are provided by GetCapabilities in the
> GetFeatureInfo-section:
> <GetFeatureInfo>
> <Format>text/plain</Format>
> <Format>application/vnd.ogc.gml</Format>
> <Format>text/xml</Format>
> <Format>application/vnd.ogc.gml/3.1.1</Format>
> <Format>text/xml; subtype=gml/3.1.1</Format>
> <Format>text/html</Format>
> <Format>application/json</Format>
> <DCPType>
> </DCPType>
> </GetFeatureInfo>
> It is a strange problem, and it took me at least some time to reproduce
> it. Today i thought, the issue is the different version, because i could
> reproduce the error with it. But later we found a new version browser that
> works correct. So i think this may be a problem in the browser settings or
> security level. Or is it possible, that IE ignores the into format settings
> in some cases? I have no idea.
> Best regards
> Uwe
> 2017-02-20 10:46 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
>> Hello,
>> Am 2017-02-20 10:31, schrieb Uwe Seher:
>>> Hello group!
>>> One of our users has a problem with the info-window on IE 11. It shows
>>> only the string [object XMLDocument]. the service behind is a
>>> geoserver, it works perfect on firefox and chrome.
>> After loading a service to an application you have to make sure, that
>> infoformat is set to text/html. I your case it is set to
>> application/vnd.ogc.gml as the GeoServer getCapabilities-XML does not
>> provide text/html as first infoformat in the xml.
>> http://doc.mapbender3.org/en/book/quickstart.html#configure-your-wms
>> The
>>> Mapbender-Version is 3.0.5.3, the logfile does not show any relating
>>> entry. I checked the versions of ie and the problem seems to be
>>> limited on the version:
>>> Version: 11.0.9600.18537
>>> Updateversion: 11.0.38 (KB3203621)
>>> The older version 11.0.9600.18097/11.0.25 (KB3100773) seem to work
>>> without problems.The IE is in default configuration. Strangely, on
>>> some installations with the newer version it works too.
>>> I had this error-mesage some other times, when there has been an error
>>> in the templates for the GetFeatureInfo-Request. I think this is a
>>> problem with the local browser with the processing of the answer to
>>> the request, but i have no idea where to look, so if someone has an
>>> idea whats the issue here, it would be great to share it.
>>> Thank you
>>> Uwe Seher
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Best regards
>> Astrid Emde
>> GIS-Consultant
>> FOSS Academy Winterschule 2017
>> 20.-24.03.2017 in Bonn
>> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
>> Astrid Emde
>> WhereGroup GmbH & Co.KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 22
>> Fax: +49(0)228 90 90 38 - 11
>> www.wheregroup.com
>> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> pgp-public key:
>> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>> Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170221/73466eb3/attachment.html>
More information about the Mapbender_users
