[Mapbender-users] Mapbender3: Handling dynamic_image/dynamic_text in print-templates
Uwe Seher
uwe.seher at gmail.com
Wed Jan 11 00:57:07 PST 2017
Yes, the feature is really great and it helps a lot. At the moment we have
also mostly one user per map but the above scenario rises at the horizon.
Maybe this could be solved when the map is assigned to a group as owner
(can raise lots of other problems) or otherwise is connected by an
attribute to a group. Then this attribute can be used in the template
instead of the user's group.
Best regards
Uwe
2017-01-11 8:46 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hello,
> Am 2017-01-11 08:25, schrieb Uwe Seher:
>> Good Morning!
>> Its always the small things. I had been logged in as administrator
>> yesterday, so no group was detected. With the correct user the
>> template works fine.
> This sounds good. Thanks for the feedback.
> I like the feature to define loggos for different groups. Like this you
> can reduce the amount of print templates.
> But this leads me directly to the next question. Which content is
>> choosen by mapbender when the user belongs to several groups and can
>> access different maps with their own logos etc?
> Good questions.
> This is not solved. At the moment the solution assumes that the user only
> belongs to one group. With more then one group it is difficult to define
> which group to choose.
> Do you have a suggestion for a good solution?
> Best regards
> Astrid
> Thank you for your help and
>> Have a lot of fun!
>> Uwe Seher
>> 2017-01-10 17:10 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
>> Hallo,
>>> it looks like you followed the instruction at.
>>> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/el
>> ements/printclient.html#configuration-of-the-element
>>> [2]
>>> Did you check the access rights for the new files on linux?
>>> Please send your odg file to me and I will have a look.
>>> Astrid
>>> Am 2017-01-10 14:47, schrieb Uwe Seher:
>>> Hello Mapbenderlist!
>>>> I like to create some print templates for some projectmaps which
>>>> should look the same with different logos and titles.
>>>> I created the odg-file and the pdf and it works fine, but the
>>>> elements
>>>> dynamic_image and dynamic_text are not filled in the resulting
>>>> map.
>>>> What i have done:
>>>> - created elements in the template (copied from Northarrow and
>>>> title
>>>> and adjusted the name to dynamic_image and dynamic_text). They are
>>>> on
>>>> the layer with the other dynamic elements.
>>>> - put the file in app/Resources/MapbenderPrintBundle/images
>>>> - adusted the owner/rights according the other files
>>>> Does it matter if the groupname has an uppercase Letter at start
>>>> (the
>>>> file is named the same)?
>>>> Maybe someone can give me a brief introducion what i have to do to
>>>> make the template work.
>>>> Thank you in advance
>>>> Uwe Seher
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
>>> Mit freundlichen Grüßen
>>> Astrid Emde
>>> GIS-Consultant
>>> FOSS Academy Winterschule 2017
>>> 20.-24.03.2017 [3] in Bonn
>>> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
>>> Astrid Emde
>>> WhereGroup GmbH & Co.KG
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Fon: +49(0)228 90 90 38 - 22 [4]
>>> Fax: +49(0)228 90 90 38 - 11 [5]
>>> www.wheregroup.com [6]
>>> Folgen Sie der WhereGroup auf twitter:
>>> http://twitter.com/WhereGroup_com [7]
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
>>> pgp-public key:
>>> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [8]
>>> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>>> Signed and/or encrypted mail is highly appreciated
>> Links:
>> [1] http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> [2]
>> [3] tel:20.-24.03.2017
>> [4] tel:%2B49%280%29228%2090%2090%2038%20-%2022
>> [5] tel:%2B49%280%29228%2090%2090%2038%20-%2011
>> [6] http://www.wheregroup.com
>> [7] http://twitter.com/WhereGroup_com
>> [8] http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Astrid Emde
> GIS-Consultant
> 20.-24.03.2017 in Bonn
> Astrid Emde
> Eifelstraße 7
> 53119 Bonn
> Germany
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Komplementärin:
> vertreten durch:
> pgp-public key:
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170111/aa4861a2/attachment-0001.html>
More information about the Mapbender_users
