[Mapbender-users] Mapbender3: Searchrouter/additional database connection
Uwe Seher
uwe.seher at gmail.com
Fri Jan 13 01:05:09 PST 2017
Hello again!
I an trying to set up a search function in my application with the search
router element.
For this i had setup an additional database connection following teh
desctioption in the documentation with the following parameters:
parameters.yml:
parameters:
# Default-Datenbank
database_driver: pdo_pgsql
database_host: 192.168.1.3
database_port: 5432
database_name: mapbender3
database_path: ~
database_user: mapbender
database_password: xxxx
# Rhein-Datenbank
database1_driver: pdo_pgsql
database1_host: 192.168.1.3
database1_port: 5432
database1_name: rhein
database1_path: ~
database1_user: gdi_user
database1_password: xxxx
config.yml:
doctrine:
dbal:
default_connection: default
connections:
default:
driver: %database_driver%
host: %database_host%
port: %database_port%
dbname: %database_name%
path: %database_path%
user: %database_user%
password: %database_password%
charset: UTF8
logging: %kernel.debug%
profiling: %kernel.debug%
rhein:
driver: %database1_driver%
host: %database1_host%
port: %database1_port%
dbname: %database1_name%
path: %database1_path%
user: %database1_user%
password: %database1_password%
charset: UTF8
orm:
auto_generate_proxy_classes: %kernel.debug%
auto_mapping: true
The search-dialog parameters look like this:
class: Mapbender\CoreBundle\Component\SQLSearchEngine
class_options:
connection: rhein
relation: mrh_1509.engstellen
attributes:
- objectid
- name
geometry_attribute: geom
form:
name:
type: choice
options:
empty_value: 'Bitte wählen'
required: true
choices:
1: 'Reg.Bereich 1'
2: 'Reg.Bereich 2'
3: 'Reg.Bereich 3'
4: 'Reg.Bereich 3'
5: 'Reg.Bereich 5'
6: 'Reg.Bereich 6'
7: 'Reg.Bereich 6'
results:
view: table
count: true
headers:
objectid: ID
callback:
event: click
options:
buffer: 10
minScale: null
maxScale: null
The dialog itself works fine, but no results are found. In the logfile i
found this entry:
[2017-01-13 08:45:04] request.CRITICAL: Uncaught PHP Exception
Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException:
"You have requested a non-existent service
"doctrine.dbal.rhein_connection". Did you mean this:
"doctrine.dbal.default_connection"?" at
/srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache line 2063
{"exception":"[object]
(Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundException(code:
0): You have requested a non-existent service
\"doctrine.dbal.rhein_connection\". Did you mean this:
\"doctrine.dbal.default_connection\"? at
/srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache:2063)"} []
So i think, the second database connection is not etablished. If i use the
parameters with other applications or psql everything works. Restarting
apache has no effect. It would be great if someone has a hint what i missed
here.
Thanks in advance
Uwe Seher
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170113/a2d762f1/attachment.html>
More information about the Mapbender_users
