[Mapbender-users] Mapbender3: Searchrouter/additional database connection
Axel Schaefer axel.schaefer at wheregroup.com
Mon Jan 16 09:01:37 PST 2017
Hi Uwe.
After changes in parameters.yml and config.yml you have to clear the
Mapbender cache directory.
The contents in: <mapbender>/(application)/app/cache.
Not the cache-directory itself, but the contents of the directory.
Maybe that's the missing point. Your configuration looks ok.
Axel
Uwe Seher writes:
> Hello again!
> I an trying to set up a search function in my application with the search
> router element.
> For this i had setup an additional database connection following teh
> desctioption in the documentation with the following parameters:
> parameters.yml:
> parameters:
>     # Default-Datenbank
>     database_driver:   pdo_pgsql
>     database_host:     192.168.1.3
>     database_port:     5432
>     database_name:     mapbender3
>     database_path:     ~
>     database_user:     mapbender
>     database_password: xxxx
>     # Rhein-Datenbank
>     database1_driver:   pdo_pgsql
>     database1_host:     192.168.1.3
>     database1_port:     5432
>     database1_name:     rhein
>     database1_path:     ~
>     database1_user:     gdi_user
>     database1_password: xxxx
> config.yml:
> doctrine:
>     dbal:
>         default_connection: default
>         connections:
>             default:
>                 driver:   %database_driver%
>                 host:     %database_host%
>                 port:     %database_port%
>                 dbname:   %database_name%
>                 path:     %database_path%
>                 user:     %database_user%
>                 password: %database_password%
>                 charset:  UTF8
>                 logging: %kernel.debug%
>                 profiling: %kernel.debug%
>             rhein:
>                 driver:   %database1_driver%
>                 host:     %database1_host%
>                 port:     %database1_port%
>                 dbname:   %database1_name%
>                 path:     %database1_path%
>                 user:     %database1_user%
>                 password: %database1_password%
>                 charset:  UTF8
>     orm:
>         auto_generate_proxy_classes: %kernel.debug%
>         auto_mapping: true
> The search-dialog parameters look like this:
> class: Mapbender\CoreBundle\Component\SQLSearchEngine
> class_options:
>     connection: rhein
>     relation: mrh_1509.engstellen
>     attributes:
>         - objectid
>         - name
>     geometry_attribute: geom
> form:
>     name:
>         type: choice
>         options:
>             empty_value: 'Bitte wählen'
>             required: true
>             choices:
>                 1: 'Reg.Bereich 1'
>                 2: 'Reg.Bereich 2'
>                 3: 'Reg.Bereich 3'
>                 4: 'Reg.Bereich 3'
>                 5: 'Reg.Bereich 5'
>                 6: 'Reg.Bereich 6'
>                 7: 'Reg.Bereich 6'
> results:
>     view: table
>     count: true
>     headers:
>         objectid: ID
>     callback:
>         event: click
>         options:
>             buffer: 10
>             minScale: null
>             maxScale: null
> The dialog itself works fine, but no results are found. In the logfile i
> found this entry:
> [2017-01-13 08:45:04] request.CRITICAL: Uncaught PHP Exception
> Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException:
> "You have requested a non-existent service
> "doctrine.dbal.rhein_connection". Did you mean this:
> "doctrine.dbal.default_connection"?" at
> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache line 2063
> {"exception":"[object]
> (Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundException(code:
> 0): You have requested a non-existent service
> \"doctrine.dbal.rhein_connection\". Did you mean this:
> \"doctrine.dbal.default_connection\"? at
> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache:2063)"} []
> So i think, the second database connection is not etablished. If i use the
> parameters with other applications or psql everything works. Restarting
> apache has no effect. It would be great if someone has a hint what i missed
> here.
> Thanks in advance
> Uwe Seher
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23 (neue Durchwahl!)
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
