[Mapbender-users] Mapbender3: Searchrouter/additional database connection
Astrid Emde
astrid.emde at wheregroup.com
Tue Jan 17 23:58:50 PST 2017
Hello,
here is another link to the documentation.
http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html#yaml-definition
geometry_attribute: geom
Make sure that your geometry_attribute is in the same projection as your
map. This is an error that often is made.
What is your EPSG-code? What are the units of your search?
buffer: 1000
Keep in mind that buffer is calutated in the units of your projection.
Astrid
Am 2017-01-17 16:15, schrieb Uwe Seher:
> Hello!
> Cleaning the cache made the trick, nor the result is shown. Thank you.
> But now the next problem:
> I interpret the documentation of the search router eleet, that the
> results are shown and you can click on it, then the map zooms to the
> element and shows the found geometry/element in the configurated
> colors.
> If i click now on my found result it zooms sometimes to an more or
> less erratic place (or does nothing) and no selected elements are
> shown. Clearing the cache after changing something didn't help here.
> The configuration is the same as above. I just post the results area:
> results:
> view: table
> count: true
> headers:
> objectid: ID
> callback:
> event: click
> options:
> buffer: 1000
> minScale: null
> maxScale: null
> styleMap:
> default:
> strokeColor: '#00ff00'
> strokeOpacity: 1
> fillOpacity: 1
> select:
> strokeColor: '#ff0000'
> fillColor: '#ff0000'
> fillOpacity: 0.8
> Any hint on the config or if i make some errors here would be great.
> Thank you
> Uwe
> 2017-01-16 18:01 GMT+01:00 Axel Schaefer
> <axel.schaefer at wheregroup.com>:
>> Hi Uwe.
>> After changes in parameters.yml and config.yml you have to clear the
>> Mapbender cache directory.
>> The contents in: <mapbender>/(application)/app/cache.
>> Not the cache-directory itself, but the contents of the directory.
>> Maybe that's the missing point. Your configuration looks ok.
>> Axel
>> Uwe Seher writes:
>>> Hello again!
>>> I an trying to set up a search function in my application with the
>> search
>>> router element.
>>> For this i had setup an additional database connection following
>> teh
>>> desctioption in the documentation with the following parameters:
>>> parameters.yml:
>>> parameters:
>>> # Default-Datenbank
>>> database_driver: pdo_pgsql
>>> database_host: 192.168.1.3
>>> database_port: 5432
>>> database_name: mapbender3
>>> database_path: ~
>>> database_user: mapbender
>>> database_password: xxxx
>>> # Rhein-Datenbank
>>> database1_driver: pdo_pgsql
>>> database1_host: 192.168.1.3
>>> database1_port: 5432
>>> database1_name: rhein
>>> database1_path: ~
>>> database1_user: gdi_user
>>> database1_password: xxxx
>>> config.yml:
>>> doctrine:
>>> dbal:
>>> default_connection: default
>>> connections:
>>> default:
>>> driver: %database_driver%
>>> host: %database_host%
>>> port: %database_port%
>>> dbname: %database_name%
>>> path: %database_path%
>>> user: %database_user%
>>> password: %database_password%
>>> charset: UTF8
>>> logging: %kernel.debug%
>>> profiling: %kernel.debug%
>>> rhein:
>>> driver: %database1_driver%
>>> host: %database1_host%
>>> port: %database1_port%
>>> dbname: %database1_name%
>>> path: %database1_path%
>>> user: %database1_user%
>>> password: %database1_password%
>>> charset: UTF8
>>> orm:
>>> auto_generate_proxy_classes: %kernel.debug%
>>> auto_mapping: true
>>> The search-dialog parameters look like this:
>>> class: Mapbender\CoreBundle\Component\SQLSearchEngine
>>> class_options:
>>> connection: rhein
>>> relation: mrh_1509.engstellen
>>> attributes:
>>> - objectid
>>> - name
>>> form:
>>> name:
>>> type: choice
>>> options:
>>> empty_value: 'Bitte wählen'
>>> required: true
>>> choices:
>>> 1: 'Reg.Bereich 1'
>>> 2: 'Reg.Bereich 2'
>>> 3: 'Reg.Bereich 3'
>>> 4: 'Reg.Bereich 3'
>>> 5: 'Reg.Bereich 5'
>>> 6: 'Reg.Bereich 6'
>>> 7: 'Reg.Bereich 6'
>>> results:
>>> view: table
>>> count: true
>>> headers:
>>> objectid: ID
>>> callback:
>>> event: click
>>> options:
>>> buffer: 10
>>> minScale: null
>>> maxScale: null
>>> The dialog itself works fine, but no results are found. In the
>> logfile i
>>> found this entry:
>>> [2017-01-13 08:45:04] request.CRITICAL: Uncaught PHP Exception
> Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException:
>>> "You have requested a non-existent service
>>> "doctrine.dbal.rhein_connection". Did you mean this:
>>> "doctrine.dbal.default_connection"?" at
>>> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache line
>> 2063
>>> {"exception":"[object]
> (Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundException(code:
>>> 0): You have requested a non-existent service
>>> \"doctrine.dbal.rhein_connection\". Did you mean this:
>>> \"doctrine.dbal.default_connection\"? at
>>> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache:2063)"}
>>> So i think, the second database connection is not etablished. If i
>> use the
>>> parameters with other applications or psql everything works.
>> Restarting
>>> apache has no effect. It would be great if someone has a hint what
>> i missed
>>> here.
>>> Thanks in advance
>>> Uwe Seher
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
>> Axel Schaefer
>> WhereGroup GmbH & Co. KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 23 [2] (neue Durchwahl!)
>> Fax: +49 (0)228 / 90 90 38 - 11 [3]
>> www.meldemax.com [4]
>> www.wheregroup.com [5]
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users [6]
> Links:
> [1] http://lists.osgeo.org/mailman/listinfo/mapbender_users
> [2] tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2023
> [3] tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2011
> [4] http://www.meldemax.com
> [5] http://www.wheregroup.com
> [6] https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Winterschule 2017
20.-24.03.2017 in Bonn
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Komplementärin:
vertreten durch:
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
