[Mapbender-users] Mapbender3: Searchrouter/additional database connection
Uwe Seher
uwe.seher at gmail.com
Wed Jan 18 00:53:04 PST 2017
Hello!
The projection didn't match. The layer is a UTM layer from a view with a
special projection from GK. In the search router i had referenced the
original layer. Now it works great. Maybe this topic could be mentioned in
the documentation or in a comment in the config.
Thank you all for your help and your work!
Best regards
Uwe
2017-01-18 8:58 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hello,
> here is another link to the documentation.
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/el
> ements/search_router.html#yaml-definition
> geometry_attribute: geom
> Make sure that your geometry_attribute is in the same projection as your
> map. This is an error that often is made.
> What is your EPSG-code? What are the units of your search?
> buffer: 1000
> Keep in mind that buffer is calutated in the units of your projection.
> Astrid
> Am 2017-01-17 16:15, schrieb Uwe Seher:
>> Hello!
>> Cleaning the cache made the trick, nor the result is shown. Thank you.
>> But now the next problem:
>> I interpret the documentation of the search router eleet, that the
>> results are shown and you can click on it, then the map zooms to the
>> element and shows the found geometry/element in the configurated
>> colors.
>> If i click now on my found result it zooms sometimes to an more or
>> less erratic place (or does nothing) and no selected elements are
>> shown. Clearing the cache after changing something didn't help here.
>> The configuration is the same as above. I just post the results area:
>> results:
>> view: table
>> count: true
>> headers:
>> objectid: ID
>> callback:
>> event: click
>> options:
>> buffer: 1000
>> minScale: null
>> maxScale: null
>> styleMap:
>> default:
>> strokeColor: '#00ff00'
>> strokeOpacity: 1
>> fillOpacity: 1
>> select:
>> strokeColor: '#ff0000'
>> fillColor: '#ff0000'
>> fillOpacity: 0.8
>> Any hint on the config or if i make some errors here would be great.
>> Thank you
>> Uwe
>> 2017-01-16 18:01 GMT+01:00 Axel Schaefer
>> <axel.schaefer at wheregroup.com>:
>> Hi Uwe.
>>> After changes in parameters.yml and config.yml you have to clear the
>>> Mapbender cache directory.
>>> The contents in: <mapbender>/(application)/app/cache.
>>> Not the cache-directory itself, but the contents of the directory.
>>> Maybe that's the missing point. Your configuration looks ok.
>>> Axel
>>> Uwe Seher writes:
>>> Hello again!
>>>> I an trying to set up a search function in my application with the
>>> search
>>>> router element.
>>>> For this i had setup an additional database connection following
>>> teh
>>>> desctioption in the documentation with the following parameters:
>>>> parameters.yml:
>>>> parameters:
>>>> # Default-Datenbank
>>>> database_driver: pdo_pgsql
>>>> database_host: 192.168.1.3
>>>> database_port: 5432
>>>> database_name: mapbender3
>>>> database_path: ~
>>>> database_user: mapbender
>>>> database_password: xxxx
>>>> # Rhein-Datenbank
>>>> database1_driver: pdo_pgsql
>>>> database1_host: 192.168.1.3
>>>> database1_port: 5432
>>>> database1_name: rhein
>>>> database1_path: ~
>>>> database1_user: gdi_user
>>>> database1_password: xxxx
>>>> config.yml:
>>>> doctrine:
>>>> dbal:
>>>> default_connection: default
>>>> connections:
>>>> default:
>>>> driver: %database_driver%
>>>> host: %database_host%
>>>> port: %database_port%
>>>> dbname: %database_name%
>>>> path: %database_path%
>>>> user: %database_user%
>>>> password: %database_password%
>>>> charset: UTF8
>>>> logging: %kernel.debug%
>>>> profiling: %kernel.debug%
>>>> rhein:
>>>> driver: %database1_driver%
>>>> host: %database1_host%
>>>> port: %database1_port%
>>>> dbname: %database1_name%
>>>> path: %database1_path%
>>>> user: %database1_user%
>>>> password: %database1_password%
>>>> charset: UTF8
>>>> orm:
>>>> auto_generate_proxy_classes: %kernel.debug%
>>>> auto_mapping: true
>>>> The search-dialog parameters look like this:
>>>> class: Mapbender\CoreBundle\Component\SQLSearchEngine
>>>> class_options:
>>>> connection: rhein
>>>> relation: mrh_1509.engstellen
>>>> attributes:
>>>> - objectid
>>>> - name
>>>> form:
>>>> name:
>>>> type: choice
>>>> options:
>>>> empty_value: 'Bitte wählen'
>>>> required: true
>>>> choices:
>>>> 1: 'Reg.Bereich 1'
>>>> 2: 'Reg.Bereich 2'
>>>> 3: 'Reg.Bereich 3'
>>>> 4: 'Reg.Bereich 3'
>>>> 5: 'Reg.Bereich 5'
>>>> 6: 'Reg.Bereich 6'
>>>> 7: 'Reg.Bereich 6'
>>>> results:
>>>> view: table
>>>> count: true
>>>> headers:
>>>> objectid: ID
>>>> callback:
>>>> event: click
>>>> options:
>>>> buffer: 10
>>>> minScale: null
>>>> maxScale: null
>>>> The dialog itself works fine, but no results are found. In the
>>> logfile i
>>>> found this entry:
>>>> [2017-01-13 08:45:04] request.CRITICAL: Uncaught PHP Exception
>>> Symfony\Component\DependencyInjection\Exception\ServiceNotFo
>> undException:
>>> "You have requested a non-existent service
>>>> "doctrine.dbal.rhein_connection". Did you mean this:
>>>> "doctrine.dbal.default_connection"?" at
>>>> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache line
>>> 2063
>>>> {"exception":"[object]
>>> (Symfony\\Component\\DependencyInjection\\Exception\\Service
>> NotFoundException(code:
>>> 0): You have requested a non-existent service
>>>> \"doctrine.dbal.rhein_connection\". Did you mean this:
>>>> \"doctrine.dbal.default_connection\"? at
>>>> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache:2063)"}
>>>> So i think, the second database connection is not etablished. If i
>>> use the
>>>> parameters with other applications or psql everything works.
>>> Restarting
>>>> apache has no effect. It would be great if someone has a hint what
>>> i missed
>>>> here.
>>>> Thanks in advance
>>>> Uwe Seher
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
>>> Axel Schaefer
>>> WhereGroup GmbH & Co. KG
>>> Eifelstraße 7
>>> 53119 Bonn
>>> Germany
>>> Fon: +49 (0)228 / 90 90 38 - 23 [2] (neue Durchwahl!)
>>> Fax: +49 (0)228 / 90 90 38 - 11 [3]
>>> www.meldemax.com [4]
>>> www.wheregroup.com [5]
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users [6]
>> Links:
>> [1] http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> [2] tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2023
>> [3] tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2011
>> [4] http://www.meldemax.com
>> [5] http://www.wheregroup.com
>> [6] https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Komplementärin:
> vertreten durch:
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170118/63dcc0b0/attachment-0001.html>
More information about the Mapbender_users
