[Mapbender-users] Mapbender3: Searchrouter/additional database connection
Astrid Emde
astrid.emde at wheregroup.com
Wed Jan 18 02:24:50 PST 2017
Hello Uwe and thanks for the suggestion.
I added a note about the projection of the geom
"Note: projection of geom has to be the same as map-Element projection"
Have a look at:
http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html#yaml-definition
Astrid
Am 2017-01-18 09:53, schrieb Uwe Seher:
> Hello!
> The projection didn't match. The layer is a UTM layer from a view with
> a special projection from GK. In the search router i had referenced
> the original layer. Now it works great. Maybe this topic could be
> mentioned in the documentation or in a comment in the config.
> Thank you all for your help and your work!
> Best regards
> Uwe
> 2017-01-18 8:58 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
>> Hello,
>> here is another link to the documentation.
>> [1]
>> geometry_attribute: geom
>> Make sure that your geometry_attribute is in the same projection as
>> your map. This is an error that often is made.
>> What is your EPSG-code? What are the units of your search?
>> buffer: 1000
>> Keep in mind that buffer is calutated in the units of your
>> projection.
>> Astrid
>> Am 2017-01-17 16:15, schrieb Uwe Seher:
>> Hello!
>> Cleaning the cache made the trick, nor the result is shown. Thank
>> you.
>> But now the next problem:
>> I interpret the documentation of the search router eleet, that the
>> results are shown and you can click on it, then the map zooms to the
>> element and shows the found geometry/element in the configurated
>> colors.
>> If i click now on my found result it zooms sometimes to an more or
>> less erratic place (or does nothing) and no selected elements are
>> shown. Clearing the cache after changing something didn't help here.
>> The configuration is the same as above. I just post the results
>> area:
>> results:
>> view: table
>> count: true
>> headers:
>> objectid: ID
>> callback:
>> event: click
>> options:
>> buffer: 1000
>> minScale: null
>> maxScale: null
>> styleMap:
>> default:
>> strokeColor: '#00ff00'
>> strokeOpacity: 1
>> fillOpacity: 1
>> select:
>> strokeColor: '#ff0000'
>> fillColor: '#ff0000'
>> fillOpacity: 0.8
>> Any hint on the config or if i make some errors here would be great.
>> Thank you
>> Uwe
>> 2017-01-16 18:01 GMT+01:00 Axel Schaefer
>> <axel.schaefer at wheregroup.com>:
>> Hi Uwe.
>> After changes in parameters.yml and config.yml you have to clear the
>> Mapbender cache directory.
>> The contents in: <mapbender>/(application)/app/cache.
>> Not the cache-directory itself, but the contents of the directory.
>> Maybe that's the missing point. Your configuration looks ok.
>> Axel
>> Uwe Seher writes:
>> Hello again!
>> I an trying to set up a search function in my application with the
>> search
>> router element.
>> For this i had setup an additional database connection following
>> teh
>> desctioption in the documentation with the following parameters:
>> parameters.yml:
>> parameters:
>> # Default-Datenbank
>> database_driver: pdo_pgsql
>> database_host: 192.168.1.3
>> database_port: 5432
>> database_name: mapbender3
>> database_path: ~
>> database_user: mapbender
>> database_password: xxxx
>> # Rhein-Datenbank
>> database1_driver: pdo_pgsql
>> database1_host: 192.168.1.3
>> database1_port: 5432
>> database1_name: rhein
>> database1_path: ~
>> database1_user: gdi_user
>> database1_password: xxxx
>> config.yml:
>> doctrine:
>> dbal:
>> default_connection: default
>> connections:
>> default:
>> driver: %database_driver%
>> host: %database_host%
>> port: %database_port%
>> dbname: %database_name%
>> path: %database_path%
>> user: %database_user%
>> password: %database_password%
>> charset: UTF8
>> logging: %kernel.debug%
>> profiling: %kernel.debug%
>> rhein:
>> driver: %database1_driver%
>> host: %database1_host%
>> port: %database1_port%
>> dbname: %database1_name%
>> path: %database1_path%
>> user: %database1_user%
>> password: %database1_password%
>> charset: UTF8
>> orm:
>> auto_generate_proxy_classes: %kernel.debug%
>> auto_mapping: true
>> The search-dialog parameters look like this:
>> class: Mapbender\CoreBundle\Component\SQLSearchEngine
>> class_options:
>> connection: rhein
>> relation: mrh_1509.engstellen
>> attributes:
>> - objectid
>> - name
>> form:
>> name:
>> type: choice
>> options:
>> empty_value: 'Bitte wählen'
>> required: true
>> choices:
>> 1: 'Reg.Bereich 1'
>> 2: 'Reg.Bereich 2'
>> 3: 'Reg.Bereich 3'
>> 4: 'Reg.Bereich 3'
>> 5: 'Reg.Bereich 5'
>> 6: 'Reg.Bereich 6'
>> 7: 'Reg.Bereich 6'
>> results:
>> view: table
>> count: true
>> headers:
>> objectid: ID
>> callback:
>> event: click
>> options:
>> buffer: 10
>> minScale: null
>> maxScale: null
>> The dialog itself works fine, but no results are found. In the
>> logfile i
>> found this entry:
>> [2017-01-13 08:45:04] request.CRITICAL: Uncaught PHP Exception
> Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException:
>>> "You have requested a non-existent service
>>> "doctrine.dbal.rhein_connection". Did you mean this:
>>> "doctrine.dbal.default_connection"?" at
>>> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache line
>> 2063
>>> {"exception":"[object]
> (Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundException(code:
>>> 0): You have requested a non-existent service
>>> \"doctrine.dbal.rhein_connection\". Did you mean this:
>>> \"doctrine.dbal.default_connection\"? at
>>> /srv/www/htdocs/mapbender3-3.0.5.3/app/bootstrap.php.cache:2063)"}
>>> So i think, the second database connection is not etablished. If i
>> use the
>>> parameters with other applications or psql everything works.
>> Restarting
>>> apache has no effect. It would be great if someone has a hint what
>> i missed
>>> here.
>>> Thanks in advance
>>> Uwe Seher
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users [2] [1]
>> Axel Schaefer
>> WhereGroup GmbH & Co. KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 [3] - 23 [2] (neue Durchwahl!)
>> Fax: +49 (0)228 / 90 90 38 [3] - 11 [3]
>> www.meldemax.com [4] [4]
>> www.wheregroup.com [5] [5]
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users [6] [6]
> Links:
> [1] http://lists.osgeo.org/mailman/listinfo/mapbender_users [2]
> [2] tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2023
> [3] tel:%2B49%20%280%29228%20%2F%2090%2090%2038%20-%2011
> [4] http://www.meldemax.com
> [5] http://www.wheregroup.com
> [6] https://lists.osgeo.org/mailman/listinfo/mapbender_users [6]
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 [7] in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 22 [8]
> Fax: +49(0)228 90 90 38 - 11 [9]
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com [10]
> Komplementärin:
> vertreten durch:
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [11]
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
> Links:
> [1]
> [2] http://lists.osgeo.org/mailman/listinfo/mapbender_users
> [7] tel:20.-24.03.2017
> [8] tel:%2B49%280%29228%2090%2090%2038%20-%2022
> [9] tel:%2B49%280%29228%2090%2090%2038%20-%2011
> [10] http://twitter.com/WhereGroup_com
> [11] http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Astrid Emde
GIS-Consultant
20.-24.03.2017 in Bonn
Astrid Emde
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
pgp-public key:
More information about the Mapbender_users
