[Mapbender-users] Mapbender don´t show map
    Teresa Graßl
    teresagrassl91 at gmail.com
    Wed Sep 20 04:14:32 PDT 2017
Hello Jörg,
I am preparing the web application for my internship and working with the
localhost on a windows server. Though the access from outside (internet) is
not possible right know.
I´ve started a new application (fullscreen template) only with the
terrestris OSM as WMS (as source, in layersets and map-element) and added a
layer tree. Now the layer/map is shown, but no layer in the layer tree.
When I choose "show header" in the layer tree dialog, the application shows
"Sources (0)" as header.
Regards,
Teresa
2017-09-20 11:43 GMT+02:00 Jörg Thomsen (WhereGroup) <
joerg.thomsen at wheregroup.com>:
> Hello Teresa,
> well, the layers should be configured as visible, but that's the default.
> I would add a layertree to the app, so I could see whether the wms are
> really added to the application. Next step, or anhother check, would be
> to check the browser request press F12 in your browser, reload the
> application and have a lok at the traffic-tab, you should see, among
> many other requests, the getmap-request.
> Is it possible to have a look at your application via internet?
> Jörg
> Am 20.09.2017 um 11:20 schrieb Teresa Graßl:
> > Hello Jörg,
> > thank you for your fast response.
> > Yes, I did add the WMS to my layersets within the application and the
> > layersets to the map-element.
> > But they are not shown when I view the application. Do I have to
> > consider other configurations within mapbender?
> > Regards,
> > Teresa
> > 2017-09-20 10:57 GMT+02:00 Jörg Thomsen (WhereGroup)
> > <joerg.thomsen at wheregroup.com <mailto:joerg.thomsen at wheregroup.com>>:
> >     Hello Teresa,
> >     I would do the first Mapbender-steps with a provided template, when
> you
> >     know what you are doing you can switch to your own template.
> >     Are the WMSs only added as a source? You also have to add them to a
> >     layerset within your application and add the Layerset to the
> map-element
> >     of your app.
> >     Regards, Jörg
> >     Am 20.09.2017 um 10:44 schrieb Teresa Graßl:
> >     > Hello,
> >     > I´m new in mapbender3 and can not show a map or any other elements
> >     in a
> >     > new application. I read through the mapbender documenation and
> >     tutorial,
> >     > but nothing worked.
> >     > I´m working on a Windows Server 2012 2R with WAPP (php, Apache,
> >     > PostgreSQL/PostGIS,..), Mapserver from MS4W and mapbender3.
> >     > My aim is to built a simple application with a map and points. My
> main
> >     > map should be the terrestris OSM
> >     (http://ows.terrestris.de/osm/service
> >     <http://ows.terrestris.de/osm/service>?)
> >     > and my points are saved as geodatabase in PostGIS. I can request my
> >     > point geometries as GetCapabilities and GetMap-Request. So
> >     MapServer is
> >     > working. Mapbender is working too, but if I include my database as
> WMS
> >     > or the terrestris WMS (as element main map), then they can not be
> >     loaded
> >     > (I can only see a white "map"-window). Unfortunetly no error
> >     massage is
> >     > shown. My points are saved as epsg:4326. The same I´m using in my
> >     > application. Both WMSs are defined and added in the sources. As
> >     Template
> >     > I used the pre-configurated Full Screen Template.
> >     > My problem is, that I´m not in programming or using php commands.
> I´ve
> >     > also tried to create a new template
> >     > (https://doc.mapbender3.org/de/book/templates.html
> >     <https://doc.mapbender3.org/de/book/templates.html>) and follwed the
> >     > tutorial, but unfortunetly the tutorial uses linux-commands and
> for me
> >     > it didn´t worked.
> >     > Has anyone configurated mapbender3 on a windows server and created
> >     a new
> >     > application yet?
> >     > I´m very grateful about any advice or help!
> >     > Cheers
> >     > Teresa
> >     > _______________________________________________
> >     > Mapbender_users mailing list
> >     > Mapbender_users at lists.osgeo.org
> >     <mailto:Mapbender_users at lists.osgeo.org>
> >     > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> >     <https://lists.osgeo.org/mailman/listinfo/mapbender_users>
> >     Viele Grüße,
> >     Jörg Thomsen
> >     INTERGEO 2017
> >     26.-28. September 2017 in Berlin
> >     Treffen Sie die WhereGroup in Halle 3.1, Stand A3.053
> >     www.intergeo.de <http://www.intergeo.de>
> >     Jörg Thomsen
> >     WhereGroup GmbH & Co. KG
> >     Gillweg 3
> >     14193 Berlin
> >     Germany
> >     Fon: +49 (0)30 / 5130 278 74
> >     <tel:%2B49%20%280%2930%20%2F%205130%20278%2074>
> >     Fax: +49 (0)30 / 89 09 53 21
> >     <tel:%2B49%20%280%2930%20%2F%2089%2009%2053%2021>
> >     www.wheregroup.com <http://www.wheregroup.com>
> >     Amtsgericht Bonn, HRA 6788
> >     Komplementärin:
> >     WhereGroup Verwaltungs GmbH
> >     vertreten durch:
> >     Olaf Knopp, Peter Stamm
> >     Folgen Sie der WhereGroup auf twitter:
> >     http://twitter.com/WhereGroup_com <http://twitter.com/WhereGroup_com
> >     Mapbender_users at lists.osgeo.org <mailto:Mapbender_users at lists.
> osgeo.org>
> Viele Grüße,
> Jörg Thomsen
> INTERGEO 2017
> www.intergeo.de
> Jörg Thomsen
> Gillweg 3
> 14193 Berlin
> Germany
> www.wheregroup.com
> Komplementärin:
> vertreten durch:
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170920/67d94c09/attachment.html>
More information about the Mapbender_users
