[Mapbender-users] Secured WMS Layers in Mapbender 3.0.8.3
Charlotte Toma (WhereGroup) charlotte.toma at wheregroup.com
Tue Aug 6 01:38:23 PDT 2019
Hi Kai Tejkl ,
Mapbender in v 3.0.8.x has problems with protected services / layers.
You can see the issue with this bug in GitHub [1]. Perhaps you could add
your WMS-source in the description of #1198 to reproduce this bug or
test the behavior after the bugfix?
The mapbender team already started to test/fix this bug - please follow
the issue for further informations.
[1] https://github.com/mapbender/mapbender/issues/1198
Greetings
Charly
Kompaktkurs Aufbau einer GDI mit Open-Source-Software
FOSS Academy Sommerschule: 23. bis 27.09.2019
https://www.foss-academy.com/kompaktkurse.html
Charlotte Toma
GIS-Consultant
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 06.08.19 um 09:25 schrieb Kai Tejkl:
> Hi All,
> I just updated from Mapbender 3.0.8 to 3.0.8.3 and got some problems
> with my WMS-Layers from my Geoserver. The Layers are protected with
> username and password and everything worked fine in the 3.0.8 version
> (just entered user and password when loading a new datasource in
> Mapbender), but with the new version I get an XML-Parse error. It
> seems to me that Mapbender can not request the WMS-Data with username
> and password, as everything works fine if I disable the security
> settings for this layer.
> Any known issues with this problem?
> Thanks for your help in advance.
> Mit freundlichen Grüßen
> i.A. Dipl.-Ing. Kai Tejkl
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190806/c77f3169/attachment.html>
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190806/c77f3169/attachment.key>
More information about the Mapbender_users mailing list
