[Mapbender-users] mapbender failed to display WMS: Ebene außerhalb der Boundingbox
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Dec 15 03:11:06 PST 2020
Hello,
in version 3.2.2 there is a bug with the BBOX calculaton.
https://github.com/mapbender/mapbender/issues/1264
A workaround is to load the WMS in 1.1.1 Version
https://geoinformatik.htw-dresden.de/ms/mbl?request=getcapabilities&service=wms&version=1.1.1
Also activate tiles as the WMS does not support large images.
See you Astrid
Am 2020-12-15 10:55, schrieb Göldner:
> Hello,
> I want to include the external WMS
> https://geoinformatik.htw-dresden.de/ms/mbl?request=getcapabilities&service=wms&version=1.3.0
> [1] to Mapbender 3.2.2, but it failed: the Layer is gray at the
> sidepane and moving over with mouse shows: “Ebene außerhalb der
> Boundingbox” (Layer outside the bounding box). The same problem
> occurs with a predefined layer (WMS features/capabilities are
> displayed well as data source) and with trying to load the WMS with
> the app header button.
> Using the same WMS in QGIS works fine, also in ArcGIS. Using the app
> I’m definitely inside a map region that has to show the WMS.
> Comparing the capabilities I didn’t find suspicious coordinates,
> only the BoundingBox use older CRS, but they are included in map
> layout. The older CRS uses reverse XY order, but OpenLayers6 is chosen
> and should know this. In map layout I tried a map extend that is much
> wider than the WMS.
> There are no hints in the app-log. Many other WMS work perfect.
> Are there any hints on possible reasons, things to test? Which values
> does the error text refer to? Maybe the capabilities are wrong, but
> how to check?
> Best regards
> Reiner Göldner
> Dr. Reiner Göldner
> Referent GIS
> ________________________________________________________________________
> LANDESAMT FÜR ARCHÄOLOGIE SACHSEN│SAXON ARCHAEOLOGICAL HERITAGE
> OFFICE
> Zur Wetterwarte 7 │01109 Dresden
> Tel: +49 351 8926 803│Fax: +49 351 8926 999
> reiner.goeldner at lfa.sachsen.de │ www.archaeologie.sachsen.de [2]
> Kein Zugang für elektronisch signierte sowie für verschlüsselte
> elektronische Dokumente
> Links:
> [1]
> [2] http://www.archaeologie.sachsen.de/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users mailing list
