[Mapbender-users] Antw: Re: Antw: Vortragsfolien QGIS2Mapbender sind online | Where2B Konferenz 2024
Daniel Grohmann Daniel.Grohmann at va.magdeburg.de
Mon Dec 16 22:03:49 PST 2024
Hallo Thorsten,
danke für deinen Tipp und ja, es gibt einen Proxy. Dieser wurde bei der
QGIS-Konfiguration auch richtig angegeben:
Einstellungen->Optionen->Netzwerk->Proxy für Webzugriff verwenden = ON,
ProxyType = DefaultProxy.
Mit der lokalen WHL-Datei sieht der pip.main-Aufruf nun wie folgt aus:
import pip
pip.main(['install', "C:/temp/fabric2-3.2.2-py3-none-any.whl"])
WARNING: pip is being invoked by an old script wrapper. This will fail
in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing
the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of
running pip directly.
Defaulting to user installation because normal site-packages is not
writeable
Processing c:\temp\fabric2-3.2.2-py3-none-any.whl
WARNING: Retrying (Retry(total=4, connect=None, read=None,
redirect=None, status=None)) after connection broken by
'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED]
certificate verify failed: unable to get local issuer certificate
(_ssl.c:1000)'))': /simple/invoke/
WARNING: Retrying (Retry(total=3, connect=None, read=None,
WARNING: Retrying (Retry(total=2, connect=None, read=None,
WARNING: Retrying (Retry(total=1, connect=None, read=None,
WARNING: Retrying (Retry(total=0, connect=None, read=None,
Could not fetch URL https://pypi.org/simple/invoke/: There was a
problem confirming the ssl certificate:
HTTPSConnectionPool(host='pypi.org', port=443): Max retries exceeded
with url: /simple/invoke/ (Caused by
(_ssl.c:1000)'))) - skipping
INFO: pip is looking at multiple versions of fabric2 to determine which
version is compatible with other requirements. This could take a while.
ERROR: Could not find a version that satisfies the requirement
invoke>=2.0 (from fabric2) (from versions: none)
ERROR: No matching distribution found for invoke>=2.0
Could not fetch URL https://pypi.org/simple/pip/: There was a problem
confirming the ssl certificate: HTTPSConnectionPool(host='pypi.org',
port=443): Max retries exceeded with url: /simple/pip/ (Caused by
1
Viele Grüße
Daniel
"Thorsten Hildebrand (WhereGroup) via Mapbender_users"
<mapbender_users at lists.osgeo.org> schrieb am 16.12.2024 um 11:17:
Hallo Daniel,
ich vermute du kannst den ersten Teil der Fehlermeldung
vernachlässigen.
Das eigentliche Problem könnte "urllib3.connection.HTTPSConnection" und
"Failed to establish a new connection" sein. Deine Umgebung kann oder
darf nicht auf die Python-Paketquellen zugreifen. Evtl. gibt es einen
HTTP(S)-Proxy?
Versuche im Browser die Bibliothek fabric2 selbst herunterzuladen:
https://pypi.org/project/fabric2/#files
Dort die untere Datei unterhalb von "Gebaute Distribution":
Danach versuchen aus der heruntergeladenen Datei zu installieren:
Viele Grüße,
Thorsten
Am 13.12.2024 um 11:52 schrieb Daniel Grohmann via Mapbender_users:
> Hallo Astrid,
> nachdem ich gestern deinen Vortrag gesehen hatte, habe ich mir das
> PlugIn QGIS2Mapbender (aus dem Repository) installiert.
> Es kam sofort eine Fehlermeldung, dass das Modul "fabric2" nicht
> installiert sei.
> Mit
> import pip
> pip.main(['install', 'fabric2'])
> in der Python-Console erschienen die folgenden Fehler:
> import pip
fail
<https://github.com/
> pypa/pip/issues/5599>for advice on fixing the underlying issue.
> 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection
> object at 0x0000011AB12BEF00>: Failed to establish a new connection:
> [Errno 11001] getaddrinfo failed')': /simple/fabric2/
> object at 0x0000011AB1042870>: Failed to establish a new connection:
> object at 0x0000011AB12DC2F0>: Failed to establish a new connection:
> object at 0x0000011AB12DC500>: Failed to establish a new connection:
> object at 0x0000011AB12DC710>: Failed to establish a new connection:
fabric2
> ERROR: No matching distribution found for fabric2
> Anscheinend ist mit Python oder pip etwas nicht in Ordnung.
> Ich verwende folgende QGIS-Umgebung (installiert über
osgeo4w-setup):
> QGIS-Version
> 3.38.3-Grenoble
> QGIS-Codeversion
> 37f9e6efee
> Qt-Version
> 5.15.13
> Python-Version
> 3.12.6
> GDAL-Version
> 3.9.2
> PROJ-Version
> 9.4.0
> EPSG-Registraturdatenbankversion
> v11.004 (2024-02-24)
> GEOS-Version
> 3.12.2-CAPI-1.18.2
> SQLite-Version
> 3.45.1
> PDAL-Version
> 2.6.3
> PostgreSQL-Client-Version
> 16.2
> SpatiaLite-Version
> 5.1.0
> QWT-Version
> 6.2.0
> QScintilla2-Version
> 2.14.1
> BS-Version
> Windows 10 Version 1809
> Beste Grüße
> Daniel Grohmann
> "Astrid Emde (WhereGroup) via Mapbender_users"
> <mapbender_users at lists.osgeo.org> schrieb am 13.12.2024 um 10:20:
> Hallo,
> gestern fand die Where2B Konferenz 2024 in Bonn | Online statt.
> https://where2b-conference.com/ <https://where2b-conference.com/>
> Ich habe dort in einem Vortrag das QGIS Plugin
> QGIS2Mapbendervorgestellt, mit dem ganz einfach QGIS Projekte
> veröffentlicht und in Mapbender eingebunden werden können.
> Die Folien finden sich auf GitHub unter
> https://github.com/astroidex/presentations/blob/master/Where2B2024/
> Where2B_2024_QGIS2Mapbender_Astrid_Emde.pdf <https://github.com/
> Where2B_2024_QGIS2Mapbender_Astrid_Emde.pdf>
> Die Folien werden bald auch im Archiv der Where2B Konferenz verlinkt
> https://where2b-conference.com/archiv/
> archiv/>
> Ich hoffe, dass das Plugin QGIS2Mapbender den Prozess der
> Veröffentlichung von Diensten vereinfachen wird und freue mich über
> Rückmeldung und Ideen zum neuen Plugin.
> Anbei auch noch der Link zur ReadMe mit Hinweisen zur Einrichtuung
> (derzeit wird noch fabric2 benötigt)
> https://github.com/WhereGroup/QGIS2Mapbender/blob/main/README.md
> <https://github.com/WhereGroup/QGIS2Mapbender/blob/main/README.md>
> Und hier noch Links zu den Vorträgen der letzen Jahr auf der Where2B
> In 2023 gab es einen Vortrag zum Thema "Mapbender 4 – spannende
Features
> des neuen Major Release".
> https://github.com/astroidex/presentations/blob/master/Where2B2023/
> Where2B_2023_Mapbender_Version_4_Astrid_Emde.pdf <https://github.com/
> Where2B_2023_Mapbender_Version_4_Astrid_Emde.pdf>
> In 2022 gab es einen Vortrag zum Thema "Versteckte Schätze - neue
und
> weniger bekannter Feature in Mapbender".
> https://where2b-conference.com/fileadmin/where2b/resources/documets/
> archive/2022/Where2B_2022_Mapbender_Astrid_Emde_HK_compressed.pdf
> <https://where2b-conference.com/fileadmin/where2b/resources/documets/
> archive/2022/Where2B_2022_Mapbender_Astrid_Emde_HK_compressed.pdf>
> english
> Hello,
> yesterday the Where2B Conference 2024 took place in Bonn | Online.
> In a presentation there I presented the QGIS plugin QGIS2Mapbender,
with
> which QGIS projects can be easily published and integrated into
> Mapbender.
> The slides can be found on GitHub at
> The slides will soon also be linked in the archive of the Where2B
> conference
> archiv/>
> I hope that the QGIS2Mapbender plugin will simplify the process of
> publishing services and look forward to receiving feedback and ideas
on
> the new plugin.
> Here is also the link to the ReadMe with instructions on how to set
it
> up (currently fabric2 is still required)
> And here are links to last year's presentations at Where2B
> In 2023 there was a presentation on “Mapbender 4 - exciting features
of
> the new major release”.
> In 2022 there was a presentation on “Hidden treasures - new and
lesser
> known features in Mapbender”.
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> Where2B 2024 - die Open-Source-GIS-Konferenz
> 12. Dezember 2024 vor Ort in Bonn und online
>	 Astrid Emde
>	 WhereGroup GmbH
>	 Eifelstraße 7
>	 53119 Bonn
>	 Germany
>	 Tel: +49(0)228 90 90 38 - 22
>	 Fax: +49(0)228 90 90 38 - 11
>	 astrid.emde at wheregroup.com
>	 www.wheregroup.com
>	 Meinen PGP Public-Key können Sie unter pgp.mit.edu
herunterladen:
> https://keys.openpgp.org/vks/v1/by-
> fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB <https://
> fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB>
>	 Signierte und/oder verschlüsselte Nachrichten sind sehr
willkommen
>	 Geschäftsführer:
>	 Olaf Knopp, Peter Stamm
>	 Amtsgericht Bonn, HRB 9885
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20241217/0fa233c6/attachment-0001.htm>
More information about the Mapbender_users mailing list
