[Mapbender-users] Fwd: Installation issues + Uncaught PHP Exception Twig\Error\RuntimeError (code 0)
    Norbert Farago
    norbert.farago at gmail.com
    Wed May 22 05:32:39 PDT 2024
Thank you Thorsten, I have just tried what  you suggested to Fabio in
another thread recently (commenting lines 11 to 17), and now the
app_dev.php started to immediately stop with "Warning:
SessionHandler::read() Session data file is not created by your
uid". (vendor/symfony/symfony/src/Symfony/Component/HttpFoundation/Session/Storage/NativeSessionStorage.php
line59)
Norbert
Norbert Farago <norbert.farago at gmail.com> ezt írta (időpont: 2024. máj.
21., K, 12:04):
> Hi Connor, hi Astrid,
> thank you for the responses! I am using (or intend to use) the latest
> version of Mapbender (3.3.5), so Symfony is 4.4.50. Unfortunately, the
> app_dev.php does not work, ("You are not allowed to access this file. Check
> app_dev.php for more information"), so you will be right, it is
> something wrong with access rights. App_console is also not allowed to be
> used, ("Warning: shell_exec() has been disabled for security reasons,
> ConfigCheckCommand.php line 201"), and the system administrators will not
> permit me to run this shell function.
> The main problem is the virtual server I got is configured under Andrew
> File System (AFS), so granting ordinary Unix/Linux write access is not
> satisfactory, it had to be configured according to the AFS permissions.
> Moreover, there is no www-data user in this environment, instead, a special
> user and a Kerberos ticket are given to me every time I want to run a php
> script. This user has the necessary read, list and write permissions on the
> Mapbender folders you mentioned. I also gave it a try to grant read, list
> and write permission to service.web, as an installation guide to Drupal
> written by the same administrators suggested to, but it does not help.
> I also checked whether php is running, but there is no problem, my simple
> php scripts are OK.
> So, the question remains, does anyone have experience with Mapbender under
> AFS, and what other access rights should I set or obtain?
> Best
> Norbert
> Astrid Emde (WhereGroup) via Mapbender_users <
> mapbender_users at lists.osgeo.org> ezt írta (időpont: 2024. máj. 17., P,
> 12:57):
>> Hello Norbert,
>> as Connor mentioned you should try the app_dev.php developer modus? It
>> will give you extra information.
>> http://localhost/mapbender/app_dev.php
>> You can also check on the console whether everything is fine
>> cd mapbender
>> app/console mapbender:config:check
>> Best regards Astrid
>> Am 2024-05-17 12:01, schrieb Härtel:
>> > Hi Norbert,
>> > which version of symfony are you using? The error of the session
>> > failing to start seems to occur in the class
>> “vendor/symfony/symfony/src/Symfony/Component/HttpFoundation/Session/Storage/NativeSessionStorage.php”
>> > (line 193), I suspect during the call to the start() function, which
>> > eventually calls the php function “session_start()”.
>> > You can check the source code on your system yourself for the real
>> > cause, though.
>> > It is possible, that the error is caused by missing write permissions
>> > on the directory or sub-directories of app/cache/ or var/cache/,
>> > depending on your Symfony version.
>> > You can also try to call the app_dev.php instead of app.php, maybe the
>> > logs for dev environment give you another indication of what is
>> > causing the error.
>> > Best regards,
>> > Connor
>> > Von: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Im
>> > Auftrag von Norbert Farago via Mapbender_users
>> > Gesendet: Donnerstag, 16. Mai 2024 10:23
>> > An: mapbender_users at lists.osgeo.org
>> > Cc: Norbert Farago <norbert.farago at gmail.com>
>> > Betreff: [Mapbender-users] Fwd: Installation issues + Uncaught PHP
>> > Dear Mapbender Team,
>> > last week I asked for a little help on the mail list, but
>> > unfortunately, I didn't get a response until now. Since then, together
>> > with the administrators, we solved the .htaccess and Apache problems,
>> > but the ones with code 0 remained. I copied here the error lines from
>> > prod.log, I am sure it will provide some extra hint for you
>> > (definitely it did not for me).
>> > [2024-05-15 23:12:52] request.INFO: Matched route "mapbender_start".
>> {"route":"mapbender_start","route_parameters":{"_route":"mapbender_start","_controller":"Mapbender\\CoreBundle\\Controller\\WelcomeController::listAction"},"request_uri":"https://
>> (...)/","method":"GET"}
>> > [2024-05-15 23:12:52] security.INFO: Populated the TokenStorage with
>> > an anonymous Token. [] []
>> > [2024-05-15 23:12:54] request.CRITICAL: Uncaught PHP Exception
>> > Twig\Error\RuntimeError: "An exception has been thrown during the
>> > rendering of a template ("Failed to start the session.")." at
>> /afs/(...)/mapbender/mapbender/src/Mapbender/ManagerBundle/Resources/views/manager.html.twig
>> > line 19 {"exception":"[object] (Twig\\Error\\RuntimeError(code: 0): An
>> > exception has been thrown during the rendering of a template (\"Failed
>> > to start the session.\"). at
>> /afs/(...)/mapbender/mapbender/src/Mapbender/ManagerBundle/Resources/views/manager.html.twig:19,
>> > RuntimeException(code: 0): Failed to start the session. at
>> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpFoundation/Session/Storage/NativeSessionStorage.php:193)"}
>> > [2024-05-15 23:12:55] request.ERROR: Uncaught PHP Exception
>> > Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No
>> > route found for "GET /favicon.ico" (from "https://(...)")" at
>> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php
>> > line 136 {"exception":"[object]
>> > (Symfony\\Component\\HttpKernel\\Exception\\NotFoundHttpException(code:
>> > 0): No route found for \"GET /favicon.ico\" (from \"https://(....)")
>> > at
>> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php:136,
>> > Symfony\\Component\\Routing\\Exception\\ResourceNotFoundException(code:
>> > 0): No routes found for \"/favicon.ico/\". at
>> /afs/(...)/mapbender/vendor/symfony/symfony/src/Symfony/Component/Routing/Matcher/Dumper/CompiledUrlMatcherTrait.php:70)"}
>> > Thank you in advance!
>> > Best
>> > Norbert Faragó
>> > _______________________________________________
>> > Mapbender_users mailing list
>> > Mapbender_users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Mit freundlichen Grüßen
>> Astrid Emde
>> GIS-Consultant
>> Aufwind durch Wissen!
>> Web-Seminare und Online-Schulungen
>> bei der www.foss-academy.com
>>    Astrid Emde
>>    WhereGroup GmbH
>>    Eifelstraße 7
>>    53119 Bonn
>>    Germany
>>    Tel: +49(0)228 90 90 38 - 22
>>    Fax: +49(0)228 90 90 38 - 11
>>    astrid.emde at wheregroup.com
>>    www.wheregroup.com
>>    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
>> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>>    Folgen Sie der WhereGroup auf twitter:
>>    http://twitter.com/WhereGroup_com
>>    Geschäftsführer:
>>    Olaf Knopp, Peter Stamm
>>    Amtsgericht Bonn, HRB 9885
>> -------------------------------_______________________________________________
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240522/3e1c0afa/attachment.htm>
More information about the Mapbender_users
