[mapguide-internals] MGOS 2.0 beta 2 candidate (again)
Jason Birch Jason.Birch at nanaimo.ca
Thu Dec 13 01:36:47 EST 2007
wITH THE CURRENT Installer, the database upgrade does not appear to
work.  AFTER WAlking through the upgrade process, I get the following
error when starting the server:
<2007-12-12T22:27:11> 			Administrator
 Error: Cannot open repository: C:\Program
Files\MapGuideOpenSource2.0\Server\Repositories\Site\MgSiteResourceConte
nts.dbxml
        The repository version '5' does not match the current version
'6'. Upgrade is required. Please refer to documentation for details.
 StackTrace:
  - MgServer.open line 1052 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_14.2\mgdev\server\
src\core\Server.cpp
  - MgServiceManager.Initialize line 145 file
src\common\manager\ServiceManager.cpp
  - MgServerResourceService.OpenRepositories line 170 file
src\services\resource\ServerResourceService.cpp
  - MgSiteRepository.MgSiteRepository line 57 file
src\services\resource\SiteRepository.cpp
  - MgRepository.VerifyAccess line 104 file
src\services\resource\Repository.cpp	Cannot open repository:
C:\Program
nts.dbxml
The repository version '5' does not match the current version '6'.
THE upgrade process also had odd output:
(sorry for odd caps; on laggy wireless)
--- Upgrading Session repository ...
Attempting to join environment: C:\Program
positoryAdmin\..\Repositories\Session
Unable to join environment C:\Program
oryAdmin\..\Repositories\Session, creating a DB_PRIVATE environment
Container upgraded: MgSessionResourceContents.dbxml
..\bin\db_upgrade: C:\Program
Files\MapGuideOpenSource2.0\Server\RepositoryAdmin
\..\Repositories\Session\MgSessionResourceData.db upgraded successfully
--- Upgrading Site repository ...
positoryAdmin\..\Repositories\Site
Program version 4.5 doesn't match environment version 92733440.0
Error opening environment C:\Program
ryAdmin\..\Repositories\Site: DbEnv::open: DB_VERSION_MISMATCH: Database
environ
ment version mismatch
--- Upgrading Library repository ...
positoryAdmin\..\Repositories\Library
Program version 4.5 doesn't match environment version 92405760.0
ryAdmin\..\Repositories\Library: DbEnv::open: DB_VERSION_MISMATCH:
Database envi
ronment version mismatch
\..\Repositories\Library\MgLibraryResourceData.db upgraded successfully
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Wednesday, December 12, 2007 10:21
To: MapGuide Internals Mail List
Subject: [mapguide-internals] MGOS 2.0 beta 2 candidate (again)
I've posted the latest beta 2 candidates again at
http://download.osgeo.org/mapguide/releases/2.0.0-beta2/, and hope to do
a general announcement on the users list tomorrow morning. The BDBXML
files should also now be installed!  (Thanks Tim)
Thanks in advance if you have a chance to check things out before I post
it.
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
