[mapguide-internals] MapGuide RFC 14 -
CartographicStylizationEngine (maybe this time I'll get it right)
Carsten Hess
carsten.hess at autodesk.com
Sat Feb 3 06:47:52 EST 2007
Andy,
you are correct we don't have the funding for the symbol library - I wish we would.
Maybe the community can pull together and create a symbol library. If everyone just submits
the symbols they created because they needed it for their own application then over time we could
end up with a pretty big library ... But now I am dreaming :)
Anyways, we used the FGDC spec just to double check that we indeed cover all the capabilities we need and
wanted. So we went through most of the hard looking symbols and either added something new to the
xml schema or said "yep can be done".
As for your question about symbol orientation the tag <AngleControl> will control whether the angle is relative
to the geometries direction or to the device coordinate space. The default value by the way os "FromGeometry"
which does exactly what you were asking for.
Cheers,
Carsten
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Andy Morsell
Sent: Fri 2/2/2007 9:24 PM
To: 'MapGuide Internals Mail List'
Cc:
Subject: RE: [mapguide-internals] MapGuide RFC 14 - CartographicStylizationEngine (maybe this time I'll get it right)
Yes, I agree that this is a one thorough RFC. I assume that the reference
to the FGDC document only pertains to the new stylization engine having the
ability to represent all of the symbols shown in the document, not to
actually create them and make available as a symbol library? I do like the
document given my degrees and past life as a geologic engineer.......
One thing that appeared to be missing was the ability to orient symbols
based on line direction. There is example 4 which demonstrates that line
direction can be understood, but many users would like symbols that depict
direction; such as water pipe flow and one-way roads. Will this be possible
with this new engine?
Andy
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, February 02, 2007 4:25 PM
To: MapGuide Internals Mail List
This RFC rocks. Amazing. I'm in awe at the breadth of functionality that
you have proposed.
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Robert Bray
Sent: Friday, February 02, 2007 13:30
Subject: [mapguide-internals] MapGuide RFC 14 - Cartographic Stylization
THIS TIME SENT AS VERY PLAIN TEXT with FIXED LINK - SORRY FOR THE SPAN ALL
All,
We would like to submit the following RFC for open discussion and
comments:
http://www.osgeo.org/trac/mapguide/wiki/MapGuideRfc14
- Note this RFC is living on our new Trac based Wiki. The other RFCs will be
moving to this location shortly.
Please respond to the list with any feedback and we will be happy to
respond.
Thanks,
Walt, Traian, Carsten, Jason (and others like Bob the admin assistant)
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
