[mapguide-internals] fdogdal, ECW, etc
Tom Fukushima tom.fukushima at autodesk.com
Tue May 22 09:46:29 EDT 2007
Hi Frank,
You had mentioned in a previous email a long time ago that you had to
change some of the build settings (to make GDAL load dynamically). Can
you tell me what those changes were, or perhaps post the vcproj files
that you used?
Also, I notice that you only mention ECW below; does this mean that
MrSID is working?
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Tuesday, May 22, 2007 7:14 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] fdogdal, ECW, etc
Tom Fukushima wrote:
> Hi Frank,
> Would you be able to post the source and binaries that you are using?
I
> think that I can get someone here to take a look at the problem this
> week.
Tom,
The binaries are available at:
   http://home.gdal.org/dl/mapguide/gdal_ecw_120.zip
The source was basically GDAL 1.3.1 and fdogdal from the 3.2.x branch at
the time I made it.  Uploading my build tree would not really be
practical
given my upload link speed.
It might also be just as well to go the other way, and have you guys
start from the standard build and see why things aren't working there. I
could do some review of the changes I made at my end and provide a
pre-built
ECW SDK for the plugin.  In fact, I believe I just used the old ecw
plugin
since that aspect has not changed at all.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
