[mapguide-internals] Discuss: RFC 48 - MapStudio Open Source
Maksim Sestic
max at geoinova.com
Mon Apr 21 03:26:24 EDT 2008
Hi Kenneth,
When MSOS hits the MGOS project, it would be great if it's wrapper API and
UI stay separated as components with their own versioning scheme. The API
part is already finding it's way in some of my ASP.NET projects... :-) All
it presently needs is porting to .NET 2.0 due to generics utilization.
Regards,
Maksim Sestic
Kenneth, GEOGRAF A/S wrote:
> I would like to clarify the "Custom .Net API" part.
> MapStudio uses an API that is seperated from the GUI.
> The part used in MapStudio is purely a wrapper for the various methods
> avalible in the HTTP interface for MapGuide.
> This is required, because the official MapGuide API assumes a dedicated
> port and somewhat trusted connection.
> On top of this, there is an Xml serializer/deserializer that converts
> between xml and .Net classes.
> Since there is a little overhead in the HTTP protocol, I decided to use
> the same interface, but use the official API to provide the connection.
> I have considered upgrading the entire application to .Net 2.0, which
> will remove the need for the patched .Net 1.1 API.
> I don't see a need to embrace the MapStudio API as an "adopted" API, but
> it does provide an easier interface to MapGuide for .Net users.
> Regards, Kenneth, GEOGRAF A/S
> Jason Birch skrev:
>> Hi all,
>> I've put up an initial draft of an RFC for bringing MapStudio Open Source
>> into the MapGuide project as discussed during the last PSC meeting:
>> https://trac.osgeo.org/mapguide/wiki/MapGuideRfc48
>> <https://trac.osgeo.org/mapguide/wiki/MapGuideRfc48>
>> Please take some time to review this RFC and provide comment. If there
>> is reasonable agreement, I would like to call a vote on this RFC sometime
>> later this week.
>> Thanks,
>> Jason
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://www.nabble.com/Discuss%3A-RFC-48---MapStudio-Open-Source-tp16791234s16610p16804112.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
