[mapguide-internals] mgos installer question/comments
Paul Spencer pspencer at dmsolutions.ca
Wed Apr 29 11:09:51 EDT 2009
using: MapGuideOpenSource-2.1.0.3832-Unofficial-0.5 bundled install on
WinXP in a VM
question: why does the installer need 900+ MB on c:\ even if you
install elsewhere?
* c:\ limited to 6GB, not enough space for an install
* added another drive (e:\) with another 6GB, will install there,
still not enough space
* remapped temp and tmp environment variables to new drive, still not
* moved virtual mem swap file to e:\, finally have 1.1 GB available
for install which is enough
* installer tells me it is going to use over 900 MB on c:\ but after
install it has only used about 500MB
comment: apache continually complains that "an unknown filter was not
added: DEFLATE" in the error log
comment: the mapguide service doesn't start automatically the first
time?
Other than that, smooth sailing! Good work!
Cheers
Paul
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the mapguide-internals mailing list
