[mapguide-internals] mgos installer question/comments
Paul Spencer pspencer at dmsolutions.ca
Wed Apr 29 12:49:38 EDT 2009
Nope, nothing under OSGeo ...
another installer question while I have your attention - should the
installer set up an Alias for the Help directory?  I didn't install
Help the first time around, so I reran it and it added the Help
directory for me (fantastic, worked but asked for a reboot?) but no
alias in the httpd.conf.  Since these are web pages, shouldn't it be
accessible as mapguide/Help or something?
Cheers
Paul
On 29-Apr-09, at 12:25 PM, Jason Birch wrote:
> Paul wrote:
>> not a big deal, just wanted to let you know in case the
>> installer was doing something it shouldn't.  My VM is
>> probably an extreme case.
> This is the second time this has come up so far in the limited
> testing we've done; not a good sign...
>> at it again its only 350 MB (only!) that is gone.  Its not
>> installer stuff in the TEMP directory so I really don't know
>> what it installed.  .NET framework stuff?
> The installer doesn't bundle the framework, so that would only be
> the case if you installed manually.  The only other component which
> should be required on the C drive is the MS Visual C++ runtime.  Did
> anything end up under C:\Program Files\OSGeo ?
>> um.  maybe I didn't reboot so lets say that is the problem :)
>> I don't recall it asking me to reboot though - should it have?
> Yes, it should have.  I'm haven't consciously noticed this recently,
> but the line that triggers this notice is still there...
> http://trac.osgeo.org/mapguide/browser/trunk/Installer/Installers/MapGuide/MapGuide.wxs#L583
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://research.dmsolutions.ca/
More information about the mapguide-internals mailing list
