[mapguide-internals] Do we need Redirect for MapGuide
WebExtension on Linux
Buddy Hu
Buddy.Hu at autodesk.com
Thu Dec 3 06:08:47 EST 2009
Thanks Dave, I will add this configuration in the mapguide.conf.
Regards,
-Buddy
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, December 03, 2009 12:04 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Do we need Redirect for MapGuide WebExtension on Linux
I have a defect logged regarding this. There is supposed to be a redirect, but it's only documented in the install guide for Linux rather than included. I requested in the defect that we include it simply commented out in the mapguide.conf on Linux. That way the user simply has to comment out the php and uncomment the java redirect.
Defect 1250359
There should be a redirect so that you don't have to reference the mapviewerjava path directly.
Regards,
Dave
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Buddy Hu
Sent: Wednesday, December 02, 2009 3:46 AM
Subject: [mapguide-internals] Do we need Redirect for MapGuide WebExtension on Linux
Hi Guys,
I encounter a defect of MapGuide Enterprise on Linux, I think MapGuide Open Source should have the same issue.
When I preview a Basic Web Layout in browser using Ajax Viewer(this is the URL: http://10.148.203.128:8008/mapguide2011/mapviewerajax/?...), there isn't nothing displayed in the map, while the toolbar and tasklist page display. I doubt we need a redirection for WebExtension with Apache+Jsp.
Because When I change the url to http://10.148.203.128:8008/mapguide2011/mapviewerjava/ajaxviewer.jsp?..., everything is ok, the map displays normally.
And another thing is, in the BuildConfigureMgOpenSourceOnWindows.pdf, we should add the following configuration for redirection in the httpd.conf like this:
Redirect /mapguide/mapviewerajax/
http://<HostName>:<Port>/mapguide/mapviewerjava/ajaxviewer.jsp
Redirect /mapguide/mapviewerdwf/
http://<HostName>:<Port>/mapguide/mapviewerjava/dwfviewer.jsp<http://%3cHostName%3e:%3cPort%3e/mapguide/mapviewerjava/dwfviewer.jsp>
However, in the BuildConfigureMgOpenSourceOnLinux<http://mapguide.osgeo.org/1.1/docs/BuildConfigureMgOpenSourceOnLinux/BuildConfigureMgOpenSourceOnLinux/Index.html>, I don't get this information for redirection. If I add a redirection in the //webserverextensions/apache2/conf/mapguide.conf, it works fine. But the weird thing is, the MapGuide Enterprise 2010 works fine even without this redirection. So I am not sure about this defect is a redirection issue.
I want to know, do we need a redirection for MG on Linux? Does anybody have experience of configure MG on Linux?
Thanks,
-Buddy Hu
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
