[mapguide-internals] FW: [mapguide-users] MapGuide runs out of
FDO connections under Fusion MGOS 2.1 Beta
Trevor Wekel
trevor_wekel at otxsystems.com
Mon Jul 27 19:43:57 EDT 2009
Hi Jason,
One quick test to perform would be to use the HTML test pages to check the status of the Fdo connection cache. In use connections could indicate bad cleanup on a feature reader somewhere. Hitting FeatureService... GetFdoCacheInfo... should display information on the open connections.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, July 27, 2009 5:28 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] FW: [mapguide-users] MapGuide runs out of FDO connections under Fusion MGOS 2.1 Beta
Importance: High
I'm really hoping that someone has time to look at this issue. It's fairly easy to replicate (see ticket below) and is a huge problem for anyone wanting to go to the current 2.1 stuff... I wonder if this was somehow introduced (or if an existing flaw became easier to run into) with the new connection handling stuff?
http://trac.osgeo.org/mapguide/ticket/1051
Jason
Sent: Monday, July 27, 2009 1:26 PM
To: mapguide-internals at lists.osgeo.org
The problem seems to be internal to MapGuide but I do basically the same
thing (select and zoom to features) in the AJAX version of my application
and it works fine. The AJAX version uses different commands from Fusion to
accomplish this so perhaps it does have to do with the way the selections
are created.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
