[mapguide-internals] FW: [mapguide-users] MapGuide runs out of
FDO connections under Fusion MGOS 2.1 Beta
Jason Birch
Jason.Birch at nanaimo.ca
Mon Jul 27 20:52:43 EDT 2009
Hi Trevor,
Yep...
Every time I do a selection, the connection number goes up by one, and each one remains open and active. None of the other SDF layers on my map ever show up on this page, regardless of how quickly I refresh it.
Same test using exact same application and version of fusion against a 2.0.x server, and SDF excluded from the pooled providers, and no connections show up at all.
Jason
________________________________________
Sent: Monday, July 27, 2009 4:43 PM
Subject: RE: [mapguide-internals] FW: [mapguide-users] MapGuide runs out of FDO connections under Fusion MGOS 2.1 Beta
One quick test to perform would be to use the HTML test pages to check the status of the Fdo connection cache. In use connections could indicate bad cleanup on a feature reader somewhere. Hitting FeatureService... GetFdoCacheInfo... should display information on the open connections.
More information about the mapguide-internals
