[mapguide-internals] Builld / Release Component Query
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jun 4 12:50:08 EDT 2009
Hi Crispin,
MapGuide 2.1 Beta is built using the released FDO 3.4.0 Windows SDK; we don't build FDO ourselves.
I personally wouldn't support using a non-released version of FDO in an official MapGuide release unless there were strong extenuating circumstances, and communication with the FDO project. I'm a bit nervous that Fusion (and its bundled OpenLayers) aren't official releases.
If a GDAL 1.6 upgrade is desired for FDO, that should probably be discussed on the fdo-internals list, for consideration in a potential FDO 3.4.1 release. In the meantime, I think that GDAL 1.6.1 is supposed to be binary-compatible with GDAL 1.6, so you may be able to just build your own GDAL or pull from the OSGeo4W distribution and swap them in.
Jason
-----Original Message-----
Sent: Thursday, June 04, 2009 4:07 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Builld / Release Component Query
I can't follow the component build process in my head at the moment - for
clarity can someone answer the following for the 2.1 build/installer process
please:
FDO - is the FDO in MG 2.1 built from trunk, a snaphot of the 3.4 release or
built from the 3.4 branch (with various fixes since the 3.4 release)?
GDAL - is this a fixed DLL or part of the build process? 1.6.1 is now
released with a load of updates for GeoRaster that would be good to have as
part of the build/installer.
Thanks in advance, Crispin
More information about the mapguide-internals
