[mapguide-internals] Builld / Release Component Query
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jun 4 14:38:31 EDT 2009
FYI, there is some problem with the released build of FDO 3.4.0:
http://lists.osgeo.org/pipermail/fdo-internals/2009-April/002833.html
AFAIK, the posted build has not been updated.
Is the installer using the posted FDO build, or a fresh build from the
actual branch?
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> Hi Crispin,
> MapGuide 2.1 Beta is built using the released FDO 3.4.0 Windows SDK; we don't build FDO ourselves.
> I personally wouldn't support using a non-released version of FDO in an official MapGuide release unless there were strong extenuating circumstances, and communication with the FDO project.  I'm a bit nervous that Fusion (and its bundled OpenLayers) aren't official releases.
> If a GDAL 1.6 upgrade is desired for FDO, that should probably be discussed on the fdo-internals list, for consideration in a potential FDO 3.4.1 release.  In the meantime, I think that GDAL 1.6.1 is supposed to be binary-compatible with GDAL 1.6, so you may be able to just build your own GDAL or pull from the OSGeo4W distribution and swap them in.
> Jason
> -----Original Message-----
> From: Crispin_at_1Spatial
> Sent: Thursday, June 04, 2009 4:07 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Builld / Release Component Query
> Hi,
> I can't follow the component build process in my head at the moment - for
> clarity can someone answer the following for the 2.1 build/installer process
> please:
> FDO - is the FDO in MG 2.1 built from trunk, a snaphot of the 3.4 release or
> built from the 3.4 branch (with various fixes since the 3.4 release)?
> GDAL - is this a fixed DLL or part of the build process?  1.6.1 is now
> released with a load of updates for GeoRaster that would be good to have as
> part of the build/installer.
>  Thanks in advance, Crispin
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
