[mapguide-internals] CS-Map in 2.1
Jackie Ng
jumpinjackie at gmail.com
Thu Mar 26 20:33:38 EDT 2009
Somehow I'm not warm to the idea of a 270MB installer. Doesn't the web tier require these dictionaries too? If we want to support a separate server / web setup, then we'd have to package an additional copy of these dictionaries, inflating it even more!
- Jackie
Oh, OK.
So these are the files that are required when displaying feature sources with different datums in the same map? That would explain why I haven't run into problems with this; we got rid of the last of our NAD27 data far before I started at the City.
I'm working on getting these packaged up into the MapGuide installer.
I believe that this addition will inflate our installer size considerably. I wonder if we should look at some kind of alternate strategy in the future, such as making a CS-Map install package a prerequisite for MapGuide. That way we could bundle CS-Map in our official releases, but not in our weekly builds.
Any idea why it was so small before; were we not supporting shifts in PROJ.4?
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Hugues Wisniewski
Sent: March-26-09 9:11 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: CS-Map in 2.1
> whatever is absolutely required for MapGuide runtime
If you use only coordinate system that never use any grid file that will work, but there are many system that use grid files in this case you'll need all the .gdc files and the grid files themselves. That's a lot of data to download but what is absolutely required for someone will be very different for someone else
Most North American users will use systems that need the grid files inside:
http://svn.osgeo.org/metacrs/csmap/trunk/CsMapDev/Dictionaries/Usa/
so, those files will be is absolutely required for them
> I'd like to help to create a CS-Map SDK windows installer
Sure, an installer is more work but I wanted to post a compiled zip file on the Cs-Map site and got carried away with other things along the year. The zip file would likely be around 200MB. Maybe a bit more
Hugues
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, March 25, 2009 10:43 PM
To: 'MapGuide Internals Mail List'
Hugues,
To keep download time reasonable, I'd like to only include the compiled dictionaries (or whatever is absolutely required for MapGuide runtime). I believe that all that's required are:
*.csv
*.mrt
*.csd
Is this correct?
For users that want to mess around with their coordinate systems, I'd like to help to create a CS-Map SDK windows installer once the MapGuide one is out of the way, including all of the code, compiled dictionaries, update utilities, docs, etc.
Jason
Sent: March-25-09 5:25 PM
The csv file is needed, that's the mapper for the EPSG and WKT engine, editable by the end user
The unneeded files in the installer, that come from http://svn.osgeo.org/metacrs/csmap/trunk/CsMapDev/Dictionaries/ are:
- the 5 asc files: coordsys.asc, datums.asc, ellipsoid.asc, mreg.asc, category.asc
- CS_COMP.c
- CS_DictDiff.c
- Compiler.mak
- Compiler.nmk
- Compiler.vcproj
Hugues
p.s: when the svn depot is created, 2.1 should point to http://svn.osgeo.org/metacrs/csmap/branches/12.01/
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/CS-Map-in-2.1-tp2535684p2541912.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
