[mapguide-internals] Installation directory structure
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 30 22:24:03 EDT 2009
C:\Program Files\OSGeo\MapGuideOpenSource
is redundant as osgeo is always opensource
how about
C:\Program Files\OSGeo\MapGuide2.1\
and what about WebTier instead of WebServerExtensions?
z
On Tue, Mar 31, 2009 at 1:21 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi All,
> There seems to be some talk that the current directory structure used by the installer is not quite ideal. If so, then what should the ideal structure be?
> I would prefer something like:
> $INSTALLDIR = C:\Program Files\OSGeo\MapGuideOpenSource
> $INSTALLDIR\Server
> $INSTALLDIR\WebServerExtensions
> $INSTALLDIR\CSMap
> This would be like the structure of previous releases, except by default it goes under the 'OSGeo' name and it will work-around the fusion having hard-coded the web server extension path. Jason suggested locking down the Server and Webextension directories which I think is a good idea. The less number of configurable paths, the better.
> Thoughts?
> - Jackie
> P.S. I didn't come up with the initial directory structure. I just went with the flow :-)
> View this message in context: http://n2.nabble.com/Installation-directory-structure-tp2560810p2560810.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
