[mapguide-internals] Toggling layers on and off in a load tester
application.
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Sep 28 02:42:22 EDT 2009
I can see what you mean with the guids being passed, it appears that it
does work.
Not sure what I did wrong back then.
The behavior parameter is described in RFC38:
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc38
The object id's (guids) change each time you generate a runtime map.
The runtime map is generated in mapframe.(aspx|php|jsp):
MgMap map = new MgMap();
MgResourceIdentifier resId = new
MgResourceIdentifier(mapDefinition);
String mapName = resId.GetName();
map.Create(resourceSrvc, resId, mapName);
Regards, Kenneth Skovhede, GEOGRAF A/S
Carl Jokl skrev:
> Never mind. This weekend I had a flash of inspiration about what the problem
> might be. It relates to the legend script page being loaded twice in
> testing. Once it is loaded to parse the group and layer information from the
> JavaScript into C# .Net objects for use in other parts of the testing but it
> also was loaded again in a separate test which just tested that the various
> frames of the viewer can be loaded. I suspect that the object ids for the
> groups and layers must change each time the Legend script frame is loaded so
> my tests would have been using old object ids for the layers and groups
> which were no longer being used.
More information about the mapguide-internals
