[mapguide-internals] Re: Managed MGOS API issues
Jackie Ng jumpinjackie at gmail.com
Mon Apr 12 20:47:40 EDT 2010
Hi Maksim,
Have you tried using a tool called gflags.exe? You can turn on extra verbose
tracing settings for dll loading, which may reveal more clues.
It may also be a PATH environment variable problem (since that is one of the
places searched when loading dlls). A hackish solution would be to
(prepend?/append?) the path containing your MapGuideUnmanagedApi.dll to the
PATH environment variable during startup/initialization before you start
using the API.
- Jackie
View this message in context: http://n2.nabble.com/Managed-MGOS-API-issues-tp4881375p4893599.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
