[mapguide-internals] Re: Managed MGOS API issues
Maksim Sestic max at geoinova.com
Tue Apr 13 05:31:07 EDT 2010
Hi Jackie, Crispin,
The exact referencing is lesser problem - I do this on MSI (installer) level
:-) as I've produced couple of handy MSM packages for each version of FDO,
GDAL, MGOS... used in a solution. Each of them get into the final Setup.exe
based on MSI feature flags (Jackie is closer to installers, I guess he'll
know what I'm referring to). I have a MSI package carrying multiple
releases, each release carrying different feature flags.
Of course, I had the same problem with FDO on Map/Civil - there's no way of
side-by-side execution (?) Well, at least that's what ADN guys suggested at
the end.
Jackie, I'll give a Gflags.exe a try - the issue here is to pinpoint exact
(referenced) dll which causes MapGuideUnmanagedApi.dll to crash. Yes, I did
try to change PATH environment variable, both with prepending and appending
my binaries path, and this didn't help either.
Crispin, if your solution worked with FDO + Map then similar thing should
work with MGOS + Map. Although I don't see how is it possible to differently
reference managed MGOS library since there's only one. Please drop in some
more hints about it if possible.
Regards,
Maksim Sestic
View this message in context: http://n2.nabble.com/Managed-MGOS-API-issues-tp4881375p4895034.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
