[mapguide-internals] /branches root directory reserved only for MapGuide?
Jason Birch jason at jasonbirch.com
Mon May 3 18:52:36 EDT 2010
I think we're going to have to agree to disagree on this one.
Although Maestro is linked to MapGuide, it is not a 1:1 relationship (unlike
Studio), and has potential to be even less linked over time.  Jackie has
plans of pulling full FDO Toolbox capabilities into Maestro, I wouldn't be
surprised to see support for GeoREST configuration / templating at some
point, and who knows... maybe someone will make it create MapServer config
files at some point :)  IMO, locking it into the MapGuide release cycle
constrains its potential.
And no, I don't really care about users getting confused about version
numbers; as long as backwards compatibility is retained they'll learn to
just grab the most recent Maestro.
Jason
On 3 May 2010 15:30, Tom Fukushima wrote:
> I thought about that version issue, and if Maestro requires a version jump
> why not jump Server and Web tier at the same time? The reverse would apply,
> that is if we jump server, then the web tier and Maestro would jump as well.
>  I think that there is an artificial separation that is being maintained
> between Maestro, server and web tier.
> Having a different release cycle introduces problems for the community to
> try to find the proper versions to use so we should try to get on the same
> cycle.  I think that patches can be put out whenever, but we should try to
> have the releases close.
> Version compatibility is easy to message if the version numbers are in
> sync!
> Of course there might be logistic problems as to why we don't want to do
> the above, but I don't know what they are.
> Putting Maestro out of sync, to me is the same as making the web tier out
> of sync with the server.
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Monday, May 03, 2010 3:16 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] /branches root directory reserved only
> for MapGuide?
> Ignoring :)
> (Maestro is generally backwards-compatible)
> Maestro is on a totally different release cycle than MapGuide. I
> wouldn't want to see the next+1 version of Maestro not be able to do a
> full-version jump (as feature additions justify) just to keep its
> version numbering in sync with MapGuide.
> We should do a better job of communicating Maestro's version
> compatibility though, in the wiki and on the splash screen...
> On 2010-05-03, Tom Fukushima <tom.fukushima at autodesk.com> wrote:
> > Hi,
> > For the following argument: I'm assuming that Maestro doesn't have the
> > capability to detect when it is working with an older server and dumb
> down
> > the XML and UI for it appropriately.  If it does have that capability
> then
> > please ignore.
> > Personally, I dislike the fact that Maestro is on its own release cycle
> with
> > its own version numbers because it makes it tougher to tell which version
> to
> > use with a particular version of MapGuide.  MapGuide does update schemas,
> > and the authoring tool should always use the latest one where possible.
>  If
> > Maestro uses the same version numbers we can see which version of MGOS it
> is
> > in sync with. Because of this I think that Maestro should use the same
> > branches that is used by the server, web tier and installer.  And because
> of
> > this I think our current directory structure is fine.
> > BTW, having Maestro, MgDev and Installer in the same branch does not mean
> > that they have to be released at the same time.
> > Cheers
> > Tom
> > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
> > Wekel
> > Sent: Monday, May 03, 2010 10:59 AM
> > Subject: RE: [mapguide-internals] /branches root directory reserved only
> for
> > MapGuide?
> > Other open source projects do follow similar trunk/branch conventions.
> > http://svn.apache.org/repos/asf/httpd/httpd/trunk/
> > http://svn.apache.org/repos/asf/httpd/httpd/branches/2.0.x/
> > http://svn.apache.org/repos/asf/httpd/httpd/branches/2.2.x/
> > I like the fact that the "Tools" resides under the MapGuide vault.  The
> > tools do not work against any other GIS product so maintaining the
> > association is reasonable in my mind.
> > Another alternative is to move Tools to the root of the tree and
> > trunk/branch each tool separately.  We sort of do this for the sandboxes
> > right now.  We should also remove Tools from mapguide/trunk/Tools once we
> > make this change.
> > http://svn.osgeo.org/mapguide/Tools/Maestro/trunk
> > http://svn.osgeo.org/mapguide/Tools/Maestro/branches/2.1
> > http://svn.osgeo.org/mapguide/Tools/GISTool/trunk
> > http://svn.osgeo.org/mapguide/Tools/GISTool/branches/1.0
> > The code bases under Maestro/trunk and Maestro/branches/2.1 should have
> an
> > identical layout.
> > Regards,
> > Trevor
> > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> > Sent: May 3, 2010 10:31 AM
> for
> > MapGuide?
> > I'm not sure why it is important that the branch structure matches the
> > trunk. MapGuide (and its related installer) is a distinct product from
> > Maestro, so the MapGuide version numbers don't make sense. We've
> > already adopted this product-based system under tags.
> > Ideally we'd have a separate svn tree (and Trac) for Maesto, but
> > didn't persue this at the time. Should this be revisited?
> > On 2010-05-03, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> >> Hmm... Branches should match the structure under trunk.  I am personally
> >> ok
> >> with having Tools out of sync with MgDev and Installer.  We should
> >> probably
> >> add a compatibility section to the wiki somewhere.
> >> /branches/2.1/Tools (whatever version 2.1 means for each of the tools,
> not
> >> in sync with MgDev and Installer)
> >> /branches/2.1/MgDev (version 2.1 for MapGuide Server and Web Extensions)
> >> /branches/2.1/Installer (installer for version 2.1 of MapGuide)
> >> Trevor
> >> Birch
> >> Sent: May 3, 2010 9:17 AM
> >> for
> >> MapGuide?
> >> Maestro versions don't normally match MapGuide versions, and are on a
> >> different release cycle. I personally feel that it would make more
> >> sense to have distinct Maestro branches than to place them within
> >> existing MapGuide branches.
> >>> I'm ok with using the existing branching mechanism. The branches should
> >>> match the trunk layout.
> >>> /branches/2.1/Tools/Maestro
> >>> (Just add Tools/Maestro)
> >>> /branches/2.2/Installer
> >>> /branches/2.2/MgDev
> >>> (At some point we should set this branch up.  Was hoping to get RFC 90
> in
> >>> first)
> >>> Regards,
> >>> Trevor
> >>> Birch
> >>> Sent: May 3, 2010 3:00 AM
> only
> >>> for
> >>> MapGuide?
> >>> I think we discussed this when we were initially bringing Maestro in.
> >>> It was a while back, but I think the intention was to just use a
> >>> prefix for the Maestro branches (/branches/Maestro-2.1, etc...)
> >>> similar to how its done in tags.
> >>> On 2010-05-03, Jackie Ng <jumpinjackie at gmail.com> wrote:
> >>>> Hi All,
> >>>> I'd like to make a "2.1" branch for Maestro since I plan to do some
> >>>> massive
> >>>> API changes/enhancements/overhauls post-2.1
> >>>> Can I put a 2.1 branch under the top-level "branches" svn directory?
> Or
> >>>> is
> >>>> this only for MapGuide's use?
> >>>> - Jackie
> >>>> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/branches-root-directory-reserved-only-for-MapGuide-tp4996834p4996834.html
> >>>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> >>>> _______________________________________________
> >>>> mapguide-internals mailing list
> >>>> mapguide-internals at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
