[mapguide-internals] /branches root directory reserved only for
MapGuide?
Tom Fukushima
tom.fukushima at autodesk.com
Mon May 3 19:20:29 EDT 2010
Great, I was unaware of these directions. Given this, I would say that Trevor's suggestion to pull it out of MapGuide trunk and give it its own trunk (or maybe eventually even its own vault) is the right thing to do.
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, May 03, 2010 4:53 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] /branches root directory reserved only for MapGuide?
I think we're going to have to agree to disagree on this one.
Although Maestro is linked to MapGuide, it is not a 1:1 relationship (unlike
Studio), and has potential to be even less linked over time. Jackie has
plans of pulling full FDO Toolbox capabilities into Maestro, I wouldn't be
surprised to see support for GeoREST configuration / templating at some
point, and who knows... maybe someone will make it create MapServer config
files at some point :) IMO, locking it into the MapGuide release cycle
constrains its potential.
And no, I don't really care about users getting confused about version
numbers; as long as backwards compatibility is retained they'll learn to
just grab the most recent Maestro.
Jason
On 3 May 2010 15:30, Tom Fukushima wrote:
> I thought about that version issue, and if Maestro requires a version jump
> why not jump Server and Web tier at the same time? The reverse would apply,
> that is if we jump server, then the web tier and Maestro would jump as well.
> I think that there is an artificial separation that is being maintained
> between Maestro, server and web tier.
> Having a different release cycle introduces problems for the community to
> try to find the proper versions to use so we should try to get on the same
> cycle. I think that patches can be put out whenever, but we should try to
> have the releases close.
> Version compatibility is easy to message if the version numbers are in
> sync!
> Of course there might be logistic problems as to why we don't want to do
> the above, but I don't know what they are.
> Putting Maestro out of sync, to me is the same as making the web tier out
> of sync with the server.
> Tom
> Sent: Monday, May 03, 2010 3:16 PM
> for MapGuide?
> Ignoring :)
> (Maestro is generally backwards-compatible)
> Maestro is on a totally different release cycle than MapGuide. I
> wouldn't want to see the next+1 version of Maestro not be able to do a
> full-version jump (as feature additions justify) just to keep its
> version numbering in sync with MapGuide.
> We should do a better job of communicating Maestro's version
> compatibility though, in the wiki and on the splash screen...
> On 2010-05-03, Tom Fukushima <tom.fukushima at autodesk.com> wrote:
> > Hi,
> > For the following argument: I'm assuming that Maestro doesn't have the
> > capability to detect when it is working with an older server and dumb
> down
> > the XML and UI for it appropriately. If it does have that capability
> then
> > please ignore.
> > Personally, I dislike the fact that Maestro is on its own release cycle
> with
> > its own version numbers because it makes it tougher to tell which version
> to
> > use with a particular version of MapGuide. MapGuide does update schemas,
> > and the authoring tool should always use the latest one where possible.
> If
> > Maestro uses the same version numbers we can see which version of MGOS it
> is
> > in sync with. Because of this I think that Maestro should use the same
> > branches that is used by the server, web tier and installer. And because
> of
> > this I think our current directory structure is fine.
> > BTW, having Maestro, MgDev and Installer in the same branch does not mean
> > that they have to be released at the same time.
> > Cheers
> > Tom
> > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
> > Wekel
> > Sent: Monday, May 03, 2010 10:59 AM
> > Subject: RE: [mapguide-internals] /branches root directory reserved only
> for
> > MapGuide?
> > Other open source projects do follow similar trunk/branch conventions.
> > http://svn.apache.org/repos/asf/httpd/httpd/trunk/
> > http://svn.apache.org/repos/asf/httpd/httpd/branches/2.0.x/
> > http://svn.apache.org/repos/asf/httpd/httpd/branches/2.2.x/
> > I like the fact that the "Tools" resides under the MapGuide vault. The
> > tools do not work against any other GIS product so maintaining the
> > association is reasonable in my mind.
> > Another alternative is to move Tools to the root of the tree and
> > trunk/branch each tool separately. We sort of do this for the sandboxes
> > right now. We should also remove Tools from mapguide/trunk/Tools once we
> > make this change.
> > http://svn.osgeo.org/mapguide/Tools/Maestro/trunk
> > http://svn.osgeo.org/mapguide/Tools/Maestro/branches/2.1
> > http://svn.osgeo.org/mapguide/Tools/GISTool/trunk
> > http://svn.osgeo.org/mapguide/Tools/GISTool/branches/1.0
> > The code bases under Maestro/trunk and Maestro/branches/2.1 should have
> an
> > identical layout.
> > Regards,
> > Trevor
> Birch
> > Sent: May 3, 2010 10:31 AM
> for
> > MapGuide?
> > I'm not sure why it is important that the branch structure matches the
> > trunk. MapGuide (and its related installer) is a distinct product from
> > Maestro, so the MapGuide version numbers don't make sense. We've
> > already adopted this product-based system under tags.
> > Ideally we'd have a separate svn tree (and Trac) for Maesto, but
> > didn't persue this at the time. Should this be revisited?
> > On 2010-05-03, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> >> Hmm... Branches should match the structure under trunk. I am personally
> >> ok
> >> with having Tools out of sync with MgDev and Installer. We should
> >> probably
> >> add a compatibility section to the wiki somewhere.
> >> /branches/2.1/Tools (whatever version 2.1 means for each of the tools,
> not
> >> in sync with MgDev and Installer)
> >> /branches/2.1/MgDev (version 2.1 for MapGuide Server and Web Extensions)
> >> /branches/2.1/Installer (installer for version 2.1 of MapGuide)
> >> Trevor
> >> Birch
> >> Sent: May 3, 2010 9:17 AM
> >> for
> >> MapGuide?
> >> Maestro versions don't normally match MapGuide versions, and are on a
> >> different release cycle. I personally feel that it would make more
> >> sense to have distinct Maestro branches than to place them within
> >> existing MapGuide branches.
> >>> I'm ok with using the existing branching mechanism. The branches should
> >>> match the trunk layout.
> >>> /branches/2.1/Tools/Maestro
> >>> (Just add Tools/Maestro)
> >>> /branches/2.2/Installer
> >>> /branches/2.2/MgDev
> >>> (At some point we should set this branch up. Was hoping to get RFC 90
> in
> >>> first)
> >>> Regards,
> >>> Trevor
> >>> Birch
> >>> Sent: May 3, 2010 3:00 AM
> only
> >>> for
> >>> MapGuide?
> >>> I think we discussed this when we were initially bringing Maestro in.
> >>> It was a while back, but I think the intention was to just use a
> >>> prefix for the Maestro branches (/branches/Maestro-2.1, etc...)
> >>> similar to how its done in tags.
> >>> On 2010-05-03, Jackie Ng <jumpinjackie at gmail.com> wrote:
> >>>> Hi All,
> >>>> I'd like to make a "2.1" branch for Maestro since I plan to do some
> >>>> massive
> >>>> API changes/enhancements/overhauls post-2.1
> >>>> Can I put a 2.1 branch under the top-level "branches" svn directory?
> Or
> >>>> is
> >>>> this only for MapGuide's use?
> >>>> - Jackie
> >>>> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/branches-root-directory-reserved-only-for-MapGuide-tp4996834p4996834.html
> >>>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> >>>> _______________________________________________
> >>>> mapguide-internals mailing list
> >>>> mapguide-internals at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
