[mapguide-internals] MapGuide RFC 119 is ready for reveiw
Zac Spitzer
zac.spitzer at gmail.com
Fri Jul 22 03:41:44 EDT 2011
yep, it pops up a tooltip and then you need to click a link
For all my projects we actually avoid all of this functionality in fusion
completely and implement a javascript module, based on the selection
even being raised, which inspects the selection response and based on
the primary key we then fire off what ever is needed.
being able to bypass the tooltip link would improve the usability, similiar
to the way the old mapguide classic used to work
z
On Fri, Jul 22, 2011 at 5:27 PM, Sam Wang <Sam.Wang at autodesk.com> wrote:
> Hi Zac,
> Yes, it will pass the same data to the client, as long as HTTP API will not
> be changed.
> I don't quite understand "enable bypassing the mini popup and simply
> launch the url immediately ". I don't know much about viewer, does it mean
> that current viewer pops up a context menu or tooltip, and then jump to a
> hyperlink?
> Thanks,
> Sam
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Friday, July 22, 2011 2:13 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide RFC 119 is ready for reveiw
> Hi Sam,
> There is no mention of updating the Ajax and Fusion viewers to support this
> change in the RFC? will this simply will pass thru the same data down to the
> client?
> what do you think about adding an new option to enable bypassing the mini
> popup and simply launch the url immediately?
> similiar to how the markers work on this map
> http://www.exploreaustralia.net.au/Victoria/Grampians-and-Central-West/Grampians-National-Park
> z
> On Fri, Jul 22, 2011 at 3:47 PM, Sam Wang <Sam.Wang at autodesk.com> wrote:
> > Hi all,
> > MapGuide RFC 119 is ready for review now. You can find it at
> > http://trac.osgeo.org/mapguide/wiki/MapGuideRfc119.
> > Please review and provide feedback.
> > Thanks,
> > Sam
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals
