Thanks Jackie for the quick response, > Also you should be using the .net 4.0 msbuild. I've updated the build.bat to > make sure this is the case. this made it! In fact previously also complained of using 3.5 msbuild against 4.0 things. Regards, Gabriele Monfardini
