[mapguide-internals] PATCH: Ticket#2032 - Selected Map Features remain visible after layer is turned off
Jackie Ng jumpinjackie at gmail.com
Tue Jun 26 06:36:13 PDT 2012
If there's a use case for the old behaviour, maybe another serverconfig.ini
configuration property is in order?
If property is true, use old rendering behaviour otherwise use behavior as
proposed in this ticket
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/PATCH-Ticket-2032-Selected-Map-Features-remain-visible-after-layer-is-turned-off-tp4983823p4983939.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
