[mapguide-internals] Patch for ticket 2379 (GETMAPLEGENDIMAGE does not handle ShowInLegend style setting and multi-style scale ranges properly)
Jackie Ng
jumpinjackie at gmail.com
Thu Nov 14 19:48:50 PST 2013
Hi Walt,
I've added a third version of the patch for review
(http://trac.osgeo.org/mapguide/attachment/ticket/2379/2379_v3.patch)
It adds an extra boolean variable to determine if a composite style was
found in the peek-ahead code, and uses this variable to skip over any
non-composite type styles in the themed code path.
And also includes the extra loop break after the rule loop as you suggested.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Patch-for-ticket-2379-GETMAPLEGENDIMAGE-does-not-handle-ShowInLegend-style-setting-and-multi-style-s-tp5089060p5089262.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
