[mapguide-users] mapagent operation=QUERYMAPFEATURES
Yewondwossen Assefa assefa at dmsolutions.ca
Thu Aug 10 09:46:10 EDT 2006
Thanks.  Small rectangle seems to do the trick with Intersects
(EnvelopeIntersects does not seem to be supported).
I was kind of looking for low level support like a point query +
tolerance but I can still simulate the tolerance in my application.
Best Regards,
Traian Stanev wrote:
> The input point is probably not *exactly* equal to the feature point and hence a point query with Intersects will not work. I would use a small rectangle query with the EnvelopeIntersects or Intersects operation. Note that by small rectangle, I don't mean a zero size rectangle, but something with width and height of say 1e-6 for example.
> Traian
> 	-----Original Message-----
> 	From: Assefa Yewondwossen
> 	Sent: Wed 8/9/2006 7:08 PM
> 	To: users at mapguide.osgeo.org
> 	Cc:
> 	Subject: [mapguide-users] mapagent operation=QUERYMAPFEATURES
> 	Hi There,
> 	  I am having trouble selecting elements on a point layer. Query looks
> 	something like this :
> 	....&operation=QUERYMAPFEATURES&geometry=POINT(663293.447226639%205431187.3623488685)&selectionVariant=INTERSECTS...
> 	  I have tried WITHIN for the selectionvariant with no success.
> 	  I have also tried a polygon geometry where the Min=Max with no success.
> 	  Note that using a polygon geometry around a point element selects the
> 	element as expected.
> 	  Any idea what I am doing wrong ?
> 	Thanks
> 	Assefa Yewondwossen
> 	Software Analyst
> 	Email: assefa at dmsolutions.ca
> 	http://www.dmsolutions.ca/
> 	Phone: (613) 565-5056 (ext 14)
> 	Fax:   (613) 565-0925
> 	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> 	For additional commands, e-mail: users-help at mapguide.osgeo.org
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
More information about the Mapguide-users mailing list
