[mapguide-users] WMS and MapGuide Enterprise 2007 problem
Andy Morsell
amorsell at spatialgis.com
Sun Jul 9 21:50:56 EDT 2006
Paul,
Thank you. That was very helpful. It didn't even occur to me to go ahead
and save the file and look it...... I agree that if text/xml was sent back
to the browser in the case of errors, this kind of trouble-shooting would be
a lot easier.
The contents of that XML do reveal a problem:
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidSRS">
The spatial reference system specified is not supported. (Found
SRS=EPSG:4326)
</ServiceException>
</ServiceExceptionReport>
I read through some of the information in the readme about enabling MapGuide
WMS to use unsupported SRS codes, but that doesn't seem to apply here. It
looks like there may be a problem with the EPSG:4326 coordinate system
definition in the OgcWmsService.config.awd file?
Andy
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Sunday, July 09, 2006 6:15 PM
Subject: Re: [mapguide-users] WMS and MapGuide Enterprise 2007 problem
Andy,
Save the result and open it up in a notepad. The text of the return may
indicate where the problem is. The whole "download" issue is a side-effect
of the OGC decision to specify their own MIME-types (why?
why?! why?!!) for the XML error returns in WMS (instead of just using
text/xml like good puppies). Your browser sees a MIME-type it doesn't
understand, cannot find a handler for it, and falls back on the only
remaining option, save it to disk. But it's just a text XML chunk, I bet,
and if your lucky it even describes your error condition in a helpful way.
Paul
On 9-Jul-06, at 12:04 PM, Andy Morsell wrote:
> Hi,
> I got MapGuide Enterprise 2007 installed and running on my development
> box yesterday (XP Pro and IIS 5, .NET web extensions) and only ran
> into a couple of snags. I am still re-configuring everything to work
> with the new version and the biggest problem I have run into is WMS
> requests not working. Whenever a standard WMS request is made (such
> as http://localhost/mapguide/mapagent/
> mapagent.fcgi?request=GetMap&service=WMS&layers=Samples/Sheboygan/
> Layers/Hydrography&srs=EPSG:
> 4326&bbox=-87.74,43.68,-87.69,43.815&width=500&height=500&format=image
> /png) I am prompted with a browser File Download dialog to download
> mapagent.fcgi. Actually, the same thing happens with a non-WMS
> MapGuide GetMap request. Thanks to Thomas Tuerke for providing the
> HTML page to test this stuff a few days ago.
> WMS appears to be configured in Admin and I changed the default server
> name of localhost:8008 to localhost (by the way, Autodesk, saving WMS
> parameters from Admin does not work in IE 7 beta, I had to use
> Firefox). Also, the layers are properly exposed to WMS via Studio.
> The only difference I can see between this configuration and my older
> MGOS install on my production server is that the WMS server name still
> says (provide your server name), but it still works. I am able to
> successfully get WMS capabilities via http://
> localhost/mapguide/mapagent/mapagent.fcgi?
> REQUEST=GetCapabilities&SERVICE=WMS&FORMAT=text/xml and everything
> looks fine there. This problem almost looks like a mime type issue,
> but I am able to make the same calls to my older system and it returns
> an image.
> So, any ideas why the request is not returning an image?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
