[mapguide-users] Taskbar Authentication Issue in IE
Andy Morsell amorsell at spatialgis.com
Mon Mar 13 12:17:24 EST 2006
I tore my main index file apart and compared to the sample application one
and everything seemed OK.  I could not for the life of me see where anything
was different.  I ended up starting from scratch with the sample app index
page and then re-inserted my custom JavaScript, additional frame in the
frameset, and any other changes and now it works fine.  I'm still baffled
why I was getting the challenge/response, but it works now.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Saturday, March 11, 2006 9:40 PM
Subject: [mapguide-users] Taskbar Authentication Issue in IE
I have a custom site using .NET that embeds an existing web layout in a
frameset.  The main index page is pretty much the same as the ASP.NET AJAX
viewer demo page from Autodesk.  The connection to the site and a session
are created programmatically in the page.  The only difference between the
demo app and my application in terms of setup is that mine does not
physically reside under the www folder and is instead located somewhere
else, but the virtual directory pathing in IIS puts it one level below
/mapguide.
However, when I open my site, the frameset and web layout open but the
standard MapGuide Open Source username and password dialog pops up.  At this
point, the entire window is built except for the task bar, leading me to
believe that this is what is causing the problem.  You can actually just say
OK or Cancel at the prompt and everything continues normally and the taskbar
builds and appears.  I dug around in the taskframe.aspx, taskbar.aspx,
taskbar.templ and taskframe.templ and suspect the problem is related to
browser detection and authentication.
This problem does not occur in Firefox and this exact setup worked fine in
MGOS 0.91.  Again, this problem does not occur with the dotnetviewersample
application.
To see this problem occur, go to
<http://mapguide.spatialgis.com/mapguide/spokanemaps/>
http://mapguide.spatialgis.com/mapguide/spokanemaps/ with Internet Explorer.
Thanks.
Andy Morsell, P.E.
 <http://www.SpatialGIS.com> http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060313/d964872a/attachment.html
More information about the Mapguide-users mailing list
