[mapguide-users] Adding URL and tooltip to generated layer
Andy Morsell
amorsell at spatialgis.com
Tue May 16 18:23:08 EDT 2006
Juan,
Are you using Studio to create your layers or are you manually editing some
existing XML files?
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, May 16, 2006 3:06 PM
Subject: RE: [mapguide-users] Adding URL and tooltip to generated layer
Alain:
Not sure. The layer is selectable. I didn't see the addition of maptips
and hyperlinks when creating new layers/markers. I would like to create
these on the fly along with the markers. I can create Property Definitions,
but didn't see a documented way to create the
I guess I could use another method of substituting values in a pre-formed
XML layer file. Just not sure if this is possible to add
maptips/hyperlinks programmatically.
- Juan
_____
From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
Sent: Tuesday, May 16, 2006 5:50 PM
Hi Juan,
There is a known problem with maptips/hyperlinks not showing in the AJAX
viewer if the layer is not selectable. Could it be the same problem here?
Alain
_____
Sent: Monday, May 15, 2006 1:12 PM
Subject: [mapguide-users] Adding URL and tooltip to generated layer
Hello:
I've got the layer creation pretty much down, but I'm having some issues
with adding the URL and the tooltip info for the markers. Has anyone been
able to do this? I left the Tooltip in the XML definition file for the
layer. I hard coded with a value and it did not come up when adding the
markers to the map.
Any info is appreciated.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060516/ea6ec6e3/attachment.html
More information about the Mapguide-users
