[mapguide-users] Street Name display - problem.
Traian Stanev
traian.stanev at autodesk.com
Wed Sep 13 09:43:14 EDT 2006
MapGuide open source uses a different labeling algorithm than MG 6.5.
The labels are actually supposed to curve along the polyline. Also, it
will attempt to reduce label duplication. In your case it seems like it
is unsuccessful at stitching together the segments that make up the
road, which is also causing the wrap-around of some of the labels. My
guess is that your road data has overlapping parallel polylines which
confuse the algorithm that stitches together the segments into one long
road feature.
Traian
-----Original Message-----
From: Maciej Skorczewski [mailto:maciej.skorczewski at procad.pl]
Sent: Wednesday, September 13, 2006 2:35 AM
Subject: [mapguide-users] Street Name display - problem.
hi
I make migration from MG 6.5 to OpenSource . And i have problem with
correct display of street name. (look in attachment or in url)
http://img245.imageshack.us/my.php?image=streetcv0.jpg
- street name are displayed in a circle (it looks like in circle), name
are in another size and they are not in line.
Street Name are from SDF file.
I use many option in Feature Label (Autodeck MapGuide Studio 2007) but
rezults is always this same.
Have you any ideas?
ps. I use Autodesk MapGuide Data Migration Tool
Maciej Skorczewski
More information about the Mapguide-users
