[mapguide-users] Newbie problem with SetFilter
peter56
ibb.scigalla at arcor.de
Thu Sep 14 03:40:41 EDT 2006
Hallo Kenneth,
thanks for reply. In addition to your indication I found a mistake in the
absolute value for the $featureResId
("Library://downtown/Data/wltg_lin.FeatureSource"). After Changing to
$featureResId = new MgResourceIdentifier($layer->GetFeatureSourceId());
the code was running.
Thank you, have a nice day - Peter
Kenneth, GEOGRAF A/S wrote:
> A quick guess, you must supply the Feature Class, not the layer name:
> $featureClass = map.GetLayers().GetItem('wltg_lin').GetFeatureClassName();
> With that, you may know replace your select with:
> $featureReader = $featureService->SelectFeatures($featureResId,
> $featureClass, $Optionen);
> Hope that helps.
> Mvh. Kenneth, GEOGRAF A/S
> peter56 skrev:
>> Hallo,
>> here a typical newbie problem with the application of the sample code.
>> Like in the php-sample "Server-side Selection" (pages 47-49) I have tried
>> to
>> select my own data. But the code don't work:
>> MgInitializeWebTier("$extensionsDir\webconfig.ini");
>> $webLayout =
>> "Library://downtown/Layouts/downtwon_layout1.WebLayout";
>> $userInfo = new MgUserInformation($mgSessionId);
>> $siteConnection = new MgSiteConnection();
>> $siteConnection->Open ($userInfo);
>> $resourceService =
>> $siteConnection->CreateService(MgServiceType::ResourceService);
>> $featureService =
>> $siteConnection->CreateService(MgServiceType::FeatureService);
>> $map = new MgMap();
>> $map->Open($resourceService, $mapName);
>> $Optionen = new MgFeatureQueryOptions();
>> $Optionen->SetFilter("MAT LIKE 'PVC%'");
>> $featureResId = new
>> MgResourceIdentifier("Library://downtown/Data/wltg_lin.FeatureSource");
>> 'wltg_lin', $Optionen);
>> "wltg_lin" is the name of the layer and the name of the data-source.
>> "MAT"
>> is an datafield and "PVC" a datavalue.
>> All data was generated by shp-files (exported from Autodesk MAP).
>> I'm working with XP, MG OS 1.0.1, Apache and php.
>> Please help to find my mistake.
>> Thanks in advance - Peter
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Newbie-problem-with-SetFilter-tf2259520.html#a6300911
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users
