[mapguide-users] MapGuide Java with Apache and SSL setup
andconfiguration
Scott Reisdorf
reisdorf1 at llnl.gov
Tue Apr 3 11:52:00 EDT 2007
Yes. It all works great now.
I just have the src pointing to a "blank.html" page I made.
-scott
Jason Birch wrote:
> Hi all,
> Another interesting post from the users list... if at all possible it
> would be nice to get these fixes into 1.2 so that users can run MGOS
> under SSL without warnings.
> Annoying IE...
> Scott, when you modified the source, did that take care of all the
> problems?
> Jason
> *From:* Scott Reisdorf
> *Subject:* Re: [mapguide-users] MapGuide Java with Apache and SSL
> setup andconfiguration
> I found the problem. I think this should be included in the next
> release.
> There are 3 places were Frames or IFrames are used with out a 'SRC'
> element
> ajaxmappane.templ - InitContextMenu() and InitToolbarFlyouts()
> framesettaskbar.templ - <frame name="scriptFrame
> framesetnotaskbar.templ - <frame name="scriptFrame
> Without the src element, using https IE shows the following message
> This page contains both secure and nonsecure items.
> More info on the message can be found here:
> http://support.microsoft.com/default.aspx?scid=kb;en-us;261188
> -scott
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070403/dddd3c90/attachment.html
