[mapguide-users] Last Function Execution in MGOS
Hidekazu Shimaji
hshimaji at ybb.ne.jp
Thu Apr 12 23:55:43 EDT 2007
Hello,
I wonder if you want to load the query page after loading the map page.
If I am right, why don't you use try-catch for javascript functions
to wait for loading the map page, like this:
var timId;
function OnLoadFunc()
try{
clearTimeout(timId);
var mapv = parent.ADViewer.GetMapFrame();
var sessionId = mapv.GetSessionId();
parent.QueryFrame.src = "querypage.aspx?SESSION=" + sessionId;
}catch(e){
timId = self.setTimeout("OnLoadFunc()", 200);
Regards,
Hidekazu Shimaji
--- Dhirendra Kumar <dhirendra.mgos at gmail.com> wrote:
> Hi All,
> I want to transfer session variable in MapGuide from external Application
> and after execution of all functions of MapGuide my query page should be
> execute and show all results on Map. Right now i can transfer session
> variable globally and use it in any page. i open MapGuide window using this
> link in the Body onload event of search page:-
http://com008:8008/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fProject%2fPandua%2fLayout%2fPLayout_Dhirendra_New.WebLayout&LOCALE=en
> But problem is here, that before succesfully execution of Map, Query get
> fire and it not get any session then it show :-
> Session has expired or is invalid. Please log in again.Session has expired
> or is invalid. Please log in again. Exception occurred in method
> MgSessionCache.GetSessionInfo at line 157 in file
c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\common\manager\SessionCache.cpp
> (for information, I blocked Login window by Providing user name and password
> Statically now mapguide window get Execute succesfully without prompting
> Login information) So, i want to know MapGuide load which function in last
> Bacause after this function i want to place my Query page and excute it and
> get All result on Map Initially. if you have Solution of this problem then
> Please Help Me..........................
> Thankyou in Advance
> Dhirendra Kumar
> http://www.nabble.com/Last-Function-Execution-in-MGOS-tf3545859s16610.html#a9898537
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
